How Do You Calculate the Final Angular Speed of a Bicycle Wheel?
The discussion revolves around calculating the final angular speed of a bicycle wheel given its initial conditions and the effects of applied torque due to friction. The problem involves concepts from rotational dynamics, including torque, angular acceleration, and moment of inertia.
  • Mixed
  • Participants explore the relationship between torque and angular acceleration, with some attempting to calculate the moment of inertia of the wheel. There are discussions about the correct interpretation of initial and final angular speeds, as well as the impact of friction on angular acceleration.
Some participants have provided guidance on the correct application of formulas, particularly regarding the sign of angular acceleration. There is ongoing exploration of the implications of these calculations, with various interpretations of the results being discussed.
There are noted discrepancies in the values used for radius and angular speed, which have led to confusion in calculations. Participants are also addressing the assumptions made about the direction of angular acceleration and its effect on the final speed.
nightshade123
[SOLVED] Angular Speed
[tex]\tau[/tex] = r * F
youve got our bicycle upside-down for repairs with its 66 cm diameter wheel spinning freely at 230 rpm. the mass of the wheel is 1.9 kg and is concentrated mostly at the rim. you hold a
wrench against the tire for 3.1s with a normal force of 2.7 N. if the coefficient of friction between the wrench and the tire is 0.46 what is the FINAL ANGULAR SPEED OF THE WHEEL?
diameter = 66 cm
radius = .033m
mass = 1.9 kg
Norm Force = 2.7 N
friction coef = .46
[tex]\omega[/tex]0 = 230 rpm
[tex]\omega[/tex]0 = 24.1 rad/s
w = ?
eqns
I = Mr^2
[tex]\omega[/tex] = [tex]\omega[/tex]0 + [tex]\alpha[/tex] * t
[tex]\tau[/tex] = r * F * sin(theta)
[tex]\tau[/tex] = I [tex]\alpha[/tex]v=[tex]\omega[/tex] * r
x
where F is the Friction Force
r*F = M * r^2 * [tex]\alpha[/tex]
we can solve for [tex]\alpha[/tex] and it = 19.08
[tex]\omega[/tex] = ( [tex]\omega[/tex]0 + [tex]\alpha[/tex] * t )[tex]\omega[/tex] = 85.48 rad/s
that means it sped up...
idk how to do this problem keep getting confused with the answers I am getting
any help?
thanks in advance for your time and effort.
initial angular speed= 230 rpm.
torque = r * f * sin 90 degrees
>> torque= .33 * .46 * 2.7 ( radius * frictional force)
calculate torque.
Now the big ques is:
What is the moment of inertia of a wheel?
nightshade123 said:
diameter = 66 cm
radius = .033m
You have a typo here that messed you up later. Radius = 0.33m.
x
Perfectly correct, except that you used the wrong value for the radius.
Note that the angular acceleration created by the friction is opposite to the initial angular velocity, so the wheel slows down.
im having trouble interpreting my answer
asuming that is right
then i put it in this eqn to find [tex]\omega[/tex] = 30.238 rad/s
so next i would take [tex]\omega[/tex] - [tex]\omega[/tex]0 to find the change over 3.1 sec?
thus producing an answer of 6.138 rad/s
and then they want to know final angular speed so 24.1 - 6.138 = 17.962 rad/ s^^^^that was the more logical approach ^^^^vvvv you can also say that vvvv
this one just produces the same answer negative, so that's why it doesn't make sense
[tex]\omega[/tex] = 24.1 rad/s
solve for [tex]\omega[/tex]0 and you get -17.962 rad/s, but then you got to change the sign, which u can because it asks for speed
That's the initial angular speed.
As I already pointed out, the acceleration is negative. Done correctly, this will give you the final speed.
The change is just alpha*time. What is your value for alpha?
Seems like you're doing a bit of extra work.
Not sure what you're doing here. Why would you solve for the initial speed? That's given.
[tex]\omega[/tex] will not increase. It will decrease. You have to put a negative sign before [tex]\alpha[/tex] in that equation.
that makes sense! and it produces the 17.962 rad/s instantly! thanks for the help
doc al, since i forgot to change accel to negative i showed how to produce the same answer, but with a lot more work, lol and i was just throwing out that idea for the 2nd part, i knew it didnt make sense but it was worth mentioning.
