How Do You Calculate the Number of Patients Hospitalized for More Than 3 Days?
  • Context: MHB
  • Thread starter Thread starter Lspencer2121
    Statistics
The discussion revolves around calculating the number of patients hospitalized for more than 3 days based on a given ratio of discharges. Participants explore the setup of the problem, the interpretation of ratios, and the application of percentages to a total number of admissions.
  • Homework-related
  • One participant seeks assistance in setting up the problem involving 12,000 admissions and the ratio of patients discharged in 3 days or less.
  • Another participant clarifies that if 6 out of 10 patients are discharged in 3 days or less, then 4 out of 10 must be hospitalized for more than 3 days.
  • A participant expresses confusion about the ratio and attempts to convert it into a fraction and decimal, questioning their calculation.
  • A later reply confirms the calculation of 4 out of 10 patients being hospitalized for more than 3 days and explains how to derive the total number from the groups of 10.
  • One participant confirms the total number of patients hospitalized for more than 3 days as 4800, based on the percentage derived from the ratio.
  • Another participant reiterates the calculation using the percentage method, affirming the result of 4800 patients.
Participants generally agree on the calculation method and the resulting number of patients hospitalized for more than 3 days, with multiple confirmations of the total being 4800. However, there is some initial confusion regarding the setup and interpretation of the ratio.
Some participants express uncertainty about the initial setup and calculations, indicating a need for clarity on how to interpret the ratio and apply it to the total admissions.
This discussion may be useful for individuals interested in mathematical reasoning related to ratios and percentages, particularly in a healthcare context.
Lspencer2121
I need help setting this problem up.
6 out of 10 patients discharged in 3 days or less, 12,000 admissions, determine how many were hospitalized over 3 days.
Thanks for the help.
If 6 out of 10 patients are discharged in 3 days or less, then how many out of ten are hospitalized for more than 3 days?
I appreciate the help but I am still clueless. I know 6/10 is a ratio, which would convert to 3/5, converts to 0.6. My thought is 0.6/12000 Am I correct?
Thanks again for the help.
If 6 out of 10 patients are discharged in 3 days or less, then 4 out of ten are hospitalized for more than 3 days.
This comes from the fact that 10 out of 10 are either discharged in 3 days or less or are hospitalized for more than 3 days. These two conditions cover everyone. So, if we let $x$ be the number out of ten that are hospitalized for more than 3 days, we must have:
$$6+x=10$$
$$x=4$$
In a total of 12,000 admissions, there are 1200 groups of 10. In each of these 1200 groups, 4 of the 10 will have been hospitalized for more than 3 days. So, we have 1200 groups of 4...how many is this?
Thank you! 4800.
Lspencer2121 said:
Thank you! 4800.
Yes, that's correct! (Sun)
Another way to look at it is since 60% are discharged in 3 days or less, then we know 40% are hospitalized for more than 3 days, and 40% of 12000 is:
$$40\%\cdot12000=\frac{40}{100}\cdot12000=40\cdot120=4800$$
  • · Replies 17 ·
