How Do You Calculate Work on a pV Diagram When Pressure Varies?
  • Thread starter Thread starter doggieslover
    Diagrams
The discussion revolves around calculating work done by a gas during a process represented on a pV diagram, specifically when pressure varies. The original poster seeks to express the work in terms of initial pressure and volume.
  • Participants discuss the formula for work done, questioning the applicability of W = p*deltaV when pressure is not constant. They explore the general form of the work equation and consider integration as a method to find work done over varying pressure.
The conversation is active, with participants examining different interpretations of the work equation and the implications of pressure being a function of volume. Some guidance on integrating pressure over volume has been provided, but no consensus has been reached on the specific application of these concepts.
Participants are working under the constraints of a specific problem context, which involves a pV diagram with varying pressure, and are attempting to reconcile their understanding of work done in thermodynamic processes.
doggieslover
W = p*deltaV only holds for the case of constant p, that is true.
What is the general form of the work eqn. that holds for all types of paths? (Hint: It also invloves p and V, and it must reduce to the W = p*deltaV, when p is constant)
Is it W = p1V1 - p2V2?
No, recall that work done is given by W = F.x, hence dW = F.dx, where dx is a infinitesimal displacement in the direction of the force.
For ideal gases, F = pA, hence dW = pA.dx, or dW = p.dV.
Work is then found from integrating p.dV, with respect to V from Vfinal to Vinitial, which can be interpreted as the area under the pV graph
So pV from Vi to Vf, but isn't p still constant in this case?
The graph indicates that p is NOT constant.
no, p as indicated in this equation of the general case, is a function of V.
okay let's say from 1 to 3, pressure is decreasing from 3p to 2p, how would I apply that to pV| from Vi to Vf?
p(3V) - p(2V)?
Integration between two points of a function can be simplified by taking the area under the curve. Because, the graph is linear, it is very easy to find the value of the integral from 1 - 3 - 6, because the area under the curve is a trapezium (or trapezoid).
  • · Replies 23 ·
12K
