How Do You Determine Position as a Function of Time from Acceleration?
  • Thread starter Thread starter MotoPayton
    Figure
12 replies · 3K views
MotoPayton
say your are giving the acceleration as a=2x and you know it has an initial velocity of 5m/s at x=0,t=0
How the heck do you find the position as function of time??
It seems so simple but really has me stumped. It must be possible.
I have played around with vdv=ads and integrated trying to unlock time..
MotoPayton said:
say you are given the acceleration as a=2x and you know it has an initial velocity of 5m/s at x=0,t=0
Write [itex]\ a=2x\[/itex] as [itex]\displaystyle\ \frac{dv}{dt}=2x\ .[/itex]
Then use the chain rule to write [itex]\displaystyle\ \frac{dv}{dt}\[/itex] as [itex]\displaystyle\ \frac{dv}{dx}\,\frac{dx}{dt}\,,\[/itex] but realize that [itex]\displaystyle\ \frac{dx}{dt}=v\ .[/itex]
That leaves you with a separable differential equation with variables, x and v .
Ya I agree, and once you separate variables and integrate you can obtain v=sqrt(2*x^2+25)
That leaves me no closer to finding the position as function of time...
MotoPayton said:
Ya I agree, and once you separate variables and integrate you can obtain v=sqrt(2*x^2+10)
That's not quite right.
It gives v = √(10) when x = 0 .
Once you fix that, remember, [itex]\displaystyle\ v=\frac{dx}{dt}\ .[/itex]
My bad I meant to write 25. My initial question was asking for the position as a function of time as the particle moves down the positive x-axis given the specific initial conditions stated above.
I don't care about the velocity as a function of x nor the velocity at x=0. Those are all easily obtainable..
I am going to move this post to advanced physics. Please don't get mad at me moderators as I think there is a simple solution to this.
Hardest problem that I can't figure out...
Moderator's Note: Multiple threads merged​
The trick is to use the chain rule to write a = dv/dt = dv/dx ##\cdot## dx/dt = v dv/dx.
See if you can use this to find v as a function of x. Then see if you can figure out a way to determine x as a function of t.
Are you familiar with differential equations? Are you sure it's not [itex]a(t) = 2t[/itex]? If you really mean [itex]a(t)= 2x(t)[/itex], then you have a second order differential equation.
oh my god I am such an idiot for not recognizing the diffeq... Thank you
I will put my head in a hole now
This thread can be deleted
As I said, [itex]\displaystyle\ \frac{dx}{dt}=v\ .[/itex]
That gives you the differential equation:
[itex]\displaystyle\ \frac{dx}{dt}=\sqrt{2\,x^2+25\,\ .}[/itex]​
... and you should care about the velocity at x=0 . That's one of your boundary conditions.
Yes, if you are familiar with 2nd order differential equations, Pengwuino's suggestion is the way to go. My suggestion involves solving a couple of first-order differential equations using separation of variables and takes more steps. Not as good.
