How Do You Determine the Angle That Maximizes Light Dispersion?
  • Thread starter Thread starter chipotleaway
    Dispersion Light
26 replies · 6K views
chipotleaway
If light moves from a medium with a refractive index that is a function of wavelength, [\itex]n_1(\lambda)[/itex], to vacuum [itex]n_2=1[/itex], then dispersion will occur. Find the incident angle [itex]\theta_1[/itex] that will maximize dispersion.
I'm interpreting 'maximum dispersion' as if we change the wavelength a little, then the angle of refraction [itex]\theta_2[/itex] should change a lot. So I think we trying to find the maximum of the function [itex]\frac{d\theta_2}{d\lambda}[/itex], which means solving [itex]\frac{d^2\theta_2}{d\lambda^2}=0[/itex] for [itex]\theta_1[/itex].
Is the correction interpretation and approach? Thanks
The question asks for the _angle_ which results in the most dispersion; your wavelength dependent index of refraction is the dispersion relationship.
So consider the total fan of light for a particular set of wavelengths - for example, the two wavelengths 400 nm and 700 nm. The rays are parallel as they approach the interface, but are "dispersed" by some angle when they leave. It is this "dispersion" angle which needs to be maximized.
You already know the angle of incidence which minimizes it: zero degrees.
You are not trying to maximise [itex]\frac{d\theta_2}{d\lambda}[/itex] wrt λ.
So I should be maximizing the difference between the diffraction angles for each wavelengths?
No. You are trying to maximise [itex]\frac{d\theta_2}{d\lambda}[/itex], but not wrt λ. What is the variable for which you are trying to pick a value?
[itex]\theta_1[/itex], which would mean [itex]\frac{d}{d\theta_1}\frac{d\theta_2}{d\lambda}[/itex]?
the function i get is [tex]\frac{cos(\theta_1)(1-n^2sin^2(\theta_1))-n^2cos(\theta_1)sin^2(\theta_1)}{(1-n^2sin^2(\theta_1))^{3/2)}[\tex]. the numerator simplifies to cos(\theta) which implies the angle is 90 degrees which can't be right. i treated each variable as a constant when differentiating with respect to the other[/tex]
[tex] Fixing the LaTex:<br /> [tex]\frac{cos(\theta_1)(1-n^2\sin^2(\theta_1))-n^2\cos(\theta_1)sin^2(\theta_1)}{(1-n^2\sin^2(\theta_1))^\frac 32}[/tex]<br /> I think you have a sign wrong there, but let's step back a bit. What do you get for ∂θ<sub>2</sub>/∂λ as a function of λ, θ<sub>1</sub> and n(λ)?[/tex]
Differentiating [tex]arcsin(n(/lambda)sin(\theta_1)[/tex], I got [tex]\frac{sin(\theta_1)}{\sqrt(1-(n(\lambda)sin(\theta_1))^2}\frac{dn(\theta_2)}{d\lambda}[/tex].
ah, i seem to have forgotten the derivative term..
chipotleaway said:
I got [tex]\frac{sin(\theta_1)}{\sqrt(1-(n(\lambda)sin(\theta_1))^2}\frac{dn(\lambda)}{d\lambda}[/tex].
(I corrected your d/dλ term.)
Right, now consider how that will behave as θ1 increases from 0.
Sorry about the latex errors (i am posting from my phone not good with the small keyboard).
It increases, and does so at faster rate for the larger n is...just looking at the plot of the expression without dn/dλ, there's no upper bound
could you please elaborate? do you mean find the max. angle of incidence from the expression?
Yes; start with Snell's law and find the maximum angle of incidence for a ray which exits the media ... do this for your shortest and longest wavelengths.
Then compare this result with the result of your calculations. Should these give the same results?
oh so the max. angle at which the ray exits. Wouldnt that just be maximizing the function of the refracted angle against the incident angle?
there are no numbers given for wavelength so I'm not sure if we're to assume visible light or not
Right, so what incident angle maximises it? (This is not a local maximum. The slope is never 0.)
Taking n(λ)=1, the plot suggests it would be as larger an incident angle (x) in the plot as possible, which would be parallel to the boundary. But that's beyond the critical angle (and light along the boundary wouldn't be refracted or reflected, I don't think).
I also realized when trying to plot for larger n(λ) values, as it should be, that the incident angle must decrease as n(λ) does ot else you get negative square roots.
This doesn't make sense to me cause there shouldn't be restrictions on the incident angle.
So the best angle of dispersion is 'infinitely' close to the critical angle..?
No, don't set n(λ)=1. That's what gave you a result beyond the critical angle. Look at this again:
[tex]\frac{sin(\theta_1)}{\sqrt(1-(n(\lambda)sin(\theta_1))^2)}\frac{dn(\theta_2)}{d\theta_1}[/tex].
As ##\theta_1## approaches the critical angle, what value does its sine tend to? What does that do to the denominator?
is that an error in your derivative term?
letting the incident angle approach the critical angle which is [itex]arcsin(\frac{1}{\lambda}[\itex], i get a 0 in the square root and 1/n in the numerator. (from evaluating the limit)[/itex]
Sorry, yes. The last bit should be dn/dλ, but it isn't important.
[itex] Exactly. So, as θ<sub>1</sub> increases towards the critical angle, the dispersion increases without limit. The maximum is therefore at the critical angle.[/itex]
