How Do You Differentiate 1/sqrt(x) Using Limits?
  • Thread starter Thread starter Pithikos
    Derivative
5 replies · 70K views
Pithikos
Find the derivative of [tex]\frac{1}{\sqrt{x}}[/tex] using the lim definition.
f(x)'=[tex]\frac{f(x+h)-f(x)}{h}[/tex]
Keep in mind that everything bellow is for the lim as h approaches 0.
[tex]\Downarrow[/tex]
[tex] \frac{<br /> \frac{1}{\sqrt{x+h}}-\frac{1}{\sqrt{x}}<br /> }<br /> {h}[/tex]
(I multiply both nominator and denominator with conjugate)
[tex] \frac<br /> {<br /> \frac{1}{x+h}-\frac{1}{x}<br /> }<br /> {<br /> \frac{h}{\sqrt{x+h}}+\frac{h}{\sqrt{x}}<br /> }[/tex]
After this I am totally lost..
Combine numerator into a single fraction. See if you get an h you can cancel with the h in the denominator.
You could also use the definition...
[tex]f'(x)= \lim_{ x \to a} \frac{f(x)- f(a)}{x-a}[/tex].
Thaaaank you! Problem solved! :)
Did the same to denominator and then combined the two franctions into one.
Glad you got it solved. As a check, remember that you can write [itex]\frac{1}{\sqrt{x}}[/itex] as [itex]x^{-1/2}[/itex] and use the power rule.
[tex] \frac<br /> {<br /> \frac{1}{x+h}-\frac{1}{x}<br /> }<br /> {<br /> \frac{h}{\sqrt{x+h}}+\frac{h}{\sqrt{x}}<br /> } [/tex]
This is perfectly fine - up to this point.
Continuing on:
[tex]\displaystyle =\frac<br /> { \displaystyle \frac{x-(x+h)}{(x+h)x}<br /> }<br /> { \displaystyle \frac{h}{\ \sqrt{x+h}}+\frac{h}{\sqrt{x}\ \ }<br /> }[/tex]
[tex]\displaystyle =\frac<br /> { \displaystyle \frac{-h}{(x+h)(x)}\ \cdot\ \displaystyle \frac{1}{h}<br /> }<br /> { \displaystyle \left(\frac{h}{\sqrt{x+h}}+\frac{h}{\sqrt{x}}\right) \ \cdot\ \displaystyle \frac{1}{h}}<br /> } [/tex]
[tex]\displaystyle =\frac<br /> { \displaystyle \frac{-1}{(x+h)(x)}<br /> }<br /> { \displaystyle \frac{1}{\sqrt{x+h}}+\frac{1}{\sqrt{x}}<br /> } [/tex]
Then,
[tex]\displaystyle f'(x)= \lim_{h\to 0} \ \ <br /> \frac<br /> { \displaystyle \frac{-1}{(x+h)(x)}<br /> }<br /> { \displaystyle \frac{1}{\sqrt{x+h}}+\frac{1}{\sqrt{x}}<br /> }[/tex]
