How do you find the charge of an atom?
  • Thread starter Thread starter alewisGB
    Atom Charge
The charge of a gold nucleus (Au) can be calculated using its atomic number, which is 79, indicating it has 79 protons. The charge of the nucleus is therefore +79 times the elementary charge, where the elementary charge is 1.6 x 10^-19 C. The electrostatic force between a proton and the gold nucleus can be calculated using the formula (Q1Q2)/4∏ε0d², where d is the distance between the charges. Understanding the atomic number is crucial for determining the charge of any atom, as it is consistently listed in the periodic table.
  • Understanding of atomic structure and atomic number
  • Familiarity with the concept of elementary charge
  • Knowledge of electrostatic force calculations
  • Ability to read and interpret the periodic table
  • Research the calculation of electrostatic forces using Coulomb's Law
  • Study the periodic table to understand atomic numbers and their significance
  • Learn about the properties of protons, neutrons, and electrons
  • Explore the concept of atomic mass versus atomic number
Students in chemistry, physicists, and anyone interested in understanding atomic charge and electrostatic interactions.
alewisGB
Calculate the electrostatic force between a proton and a gold nucleus Au with a distance 7.5x10-13m
19797Au
The Electrostatic force is (Q1Q2)/4∏ε0d2
Two things I want to know, the charge of the gold and how to find the charge of Atoms!
All I need to know is the charge, I can do the rest!
Au has 97 protons (and electrons) therefore the charge on the nucleus is +97 x electron charge. The charge on the proton is +1 electron charge
Electron charge is 1.6 x 10 ^-19 C
Thanks!
That is what it is but your question was how do you find out? What will you do if the next question is about lead or other element nucleus?
You didn't know that is the atomic number which you will find in every periodic table, not to be confused with atomic mass which you will find in the same table?
technician said:
Au has 97 protons
No it does not.
Let's please let the OP find the correct number.
sorry Redbelly98 and alewisGB! __ protons not 97.
Very sloppy of me, easy to check with periodic table. I suppose whether it is gold or not is irrelevant, OP should find out what to look for.
As I said, let the OP find the correct number. (As you said, it's easy to check with periodic table.)
