How Do You Integrate (u^4 + 1) / (u^5 + 3u)?
  • Thread starter scottshannon
    Integral
6 replies · 2K views · last reply
scottshannon
Integral (u^4 +1) du/(u^5+3u)
I don't know how to solve this integral. I don't know how to simplify it or what to do.
It is not a form of dt/t. I tried to substitute trig functions and got nowhere. I thought it might be able to be solved by partial fractions but no.
Partial fractions is in fact a good idea, although a little tricky. Here's a hint. Try$$
\frac{u^4+1}{u^5+3u}=\frac{u^4+1}{u(u^4+3)}=\frac A u +\frac {Bu^3}{u^4+3}$$
Thank you. I will see how that works, although I probably would have tried Bu^4+ Cu^3 +Du^2 +Eu +F. How do you know C, D, E and F = 0? I am asking myself this question.
Perhaps LCKurtz is cleverer than either of us, but I would have made it easier than you by doing:
##\frac{A}{u} + \frac{X}{u^4 + 3}## where ##A## is a constant and ##X## is a polynomial in ##u##. You can then solve for ##X## without all the variables for each coefficient. Perhaps then half way through this calculation, like me, you see the shortcut that LCK saw.
In general, a partial fraction for
[tex]f(u) = \frac{u^4+1}{u(u^4+3)}[/tex]
would have the form of a sum of terms like ##P(u)/Q(u)##, where the degree of ##P## is at least one less than the degree of ##Q##. Thus
[tex]\begin{array}{rcl} \displaystyle \frac{u^4+1}{u(u^4+3)} &=& \displaystyle \frac{A}{u} + \frac{Bu^3 + Cu^2 + Du+E}{u^4+3}\\<br /> & =& \displaystyle \frac{A(u^4+3) + u(Bu^3 + Cu^2 + Du+E)}{u(u^4+3)}<br /> \end{array}[/tex]
The numerator above is a polynomial of degree 4 that must be equal to ##u^4+1## for all u, so you can determine unique values of ##A,B,C,D,E## from that.
I wasn't sure it would work, but noticing that the numerator had only ##u^4## and a constant term, and that my proposed partial fractions would generate only terms like that, it seemed worth trying it. Had it not worked, one of the methods others have suggested would have been necessary.
A way to get this: (not necessarily any better than what's been said)
##\displaystyle \frac{u^4+1}{u^5+3u} ##
##\displaystyle = \frac{3u^4+3}{3u(u^4+3)} ##
##\displaystyle = \frac{2u^4 +u^4+3}{3u(u^4+3)} ##
##\displaystyle = \frac{2u^4}{3u(u^4+3)}+ \frac{u^4+3}{3u(u^4+3)} ##
##\displaystyle = \frac{2u^3}{3(u^4+3)}+ \frac{1}{3u} ##​
