jim1174
- 79
when I am adding, subtracting, multiplying and dividing fractions and I get an answer is there a way I can check to make sure my answer is in lowest terms ?
To determine if a fraction is in lowest terms, check for common factors between the numerator and denominator. If any prime factors are shared, the fraction can be simplified. For example, the fraction 10/15 simplifies to 2/3 by canceling the common factor of 5. For larger numbers, use the Euclidean algorithm to find the greatest common divisor (GCD); if the GCD is 1, the fraction is in lowest terms. The discussion emphasizes both prime factorization and the GCD method as effective techniques for simplification.
PREREQUISITESStudents, educators, and anyone looking to improve their understanding of fraction simplification and mathematical problem-solving techniques.
The short answer is: the fraction is in lowest terms if there are no factors other than 1 that appear in both the numerator and denominator.jim1174 said:when I am adding, subtracting, multiplying and dividing fractions and I get an answer is there a way I can check to make sure my answer is in lowest terms ?
If the numbers are really small, by inspection. However in general no, except by brute force. Example: 91/143.jim1174 said:when I am adding, subtracting, multiplying and dividing fractions and I get an answer is there a way I can check to make sure my answer is in lowest terms ?
HallsofIvy said:Or simply factor the numerator and denominator to prime factors. In mathman's "91/143" example, 91 is not divisible by 2, 3, or 5 but 91= 7(13) and 13 is also prime. 143 is not divisible by 2, 3, 5, or 7 but 143= 11(13). Since 91 and 143 have prime factor 13 in common, the fraction 91/143= (7(13))/(11(13)) is not "reduced to lowest terms" we can reduce further by cancelling the "13" in both numerator and denominator to get 7/11 which is "reduced to lowest terms.
To apply willem2's suggestion, n91 divides into 143 once with remainder 143- 91= 52. 52 divides into 91 once with remainder 91- 52= 39. 39 divides into 52 once with remainder 52- 39= 13. And 13 divides into 39 exactly three times with no remainder: 39= 3(13). That immediately tells us that the two numbers, 143 and 91 have common factor 13.
To see that this is true, since 39= 3(13), 52- 39= 52- 3(13)= 13 so 53= 4(13). Then 91- 52= 91- 4(13)= 3(13) so 91= 7(13). And then 143- 91= 143- 7(13)= 4(13) so 143= 11(13).
