How Do You Multiply Multiple Percentages Correctly?
  • Thread starter chriscarson
    Confused
28 replies · 4K views · last reply
chriscarson
multiplication of percentage
x
94% * 91% * 91% = 78.8%
how does this becomes like that?, I m havig the result of 778414
The % sign can essentially be interpreted as ##\times 0.01##, i.e. ##36 \% \equiv 36 \times 0.01 = 0.36##
chriscarson said:
Homework Statement:: multiplication of percentage
Relevant Equations:: x
Can you multiply$$\frac{94}{100} \times \frac{91}{100} \times \frac{91}{100}$$What do you get?
no , maybe that s why
If you google for "multiplication of fractions", you get links such as this.
What part is causing you difficulty?
so 0.94 x 0.91 x 0.91 = 0.778414 ?
Yes. Now express that result as a percentage.
well just don t know what to do but it seem with the example to make them 0.91 etc you can multiply then divide by 100
just divide by 100 ? because it becomes 77.8414 not 78.8%
Apparently you just multiplied 94 x 91 x 91.
If 78.8% is the answer in your book, it looks like they rounded the result to the nearest tenth of a percent.
BTW, I moved this thread from Intro Physics to Precalc Math -- the question really has little to do with physics.
It looks like they rounded it and then goofed with an off-by-one in the second digit. Or a similar brain-o.
I missed that change. I think you're right, though.
ok
chriscarson said:
but this does not effect to multiplicate the percentages right ?
No. It was a sidebar.
50x50 = 2500
50% x 50% = 25%
BTW, a mnemonic that often helped me intuitively understand operations like this is that you can think of the "multiplication" operator to mean "of" - as in "a certain amount of pie".
So:
50% x 50%
is the same as
50% of 50%
is the same as
a half of a half.
which is, intuitively, 1/4 - or 25%.
Pie chart with one quarter pulled out and labeled "50% of 50% of a pie", with an arrow pointing to the separated quarter slice.
50x50 = 2500
50% x 50% = 25%
So:
50% x 50%
is the same as
50% of 50%
is the same as
a half of a half.
good , seems good to remember , have to see when it s a multiplication of 10 numbers.
It's just a mnemonic - a memory aid. You don't have to use it to do the calculation - just keep it in mind so you know how the numbers should be behaving,
oh I see ,ok
BTW, it doesn't just work with fractions and percentages. It works with whole numbers too.
eg. : two cartons of a dozen eggs gives you ... how many eggs?
Now that I remember in class,we did ...
88.2% x 94.7% x 86% = 71.8%
and it was with a scientific calculator, anybody knows what we pressed for it so maybe I remember?
You mean something like:
Screenshot of Google's scientific calculator showing the expression 88.2% × 94.7% × 86% = 0.71831844, with Rad/Deg, trig, log and memory keys below.
D
Yes that is what the percentage sign means, per is 'divided by' and cent is a 100.
The sign tells you too, it's jumbled up dividing line with 2 noughts.
  • Handwritten notes on lined paper: "% means 1/100 per = divided by cent = 100" and "8% of 50 means 8/100 x 50 = 4", with arrows linking the terms.
pinball1970 said:
D
I discovered that I had to make 0.71831844 x 100 to get 71.8
pinball1970 said:
D
88.2% x 94.7% x 86% written in calculator becomes like this
Casio fx-82EX calculator screen showing 88.2%×94.7%×86% with result 0.71831844, then Ans×100 giving 71.831844.
had to make times not division
Yes they are expressed as decimals. One whole is 100 per cent or 100 out of 100 = 1.0
71.831844 as a % is that amount out of 100, 71.8314833/100 which is = 0.71834.
If you get stuck remember what you are doing going from fractions to % to decimals and back.
Use the easiest eg so you know. One half
Handwritten notes on lined paper, rotated: Half is the same as 50% = 50/100; so 1/2 = 50/100, you can cancel 50/100 to 1/2; 1 ÷ 2 on your calc will give you 0.5; so 50% = 50/100 = 1/2 = 0.5, with 50/100 and 0.5 circled and arrows linking them.
yes it s forth and back from what you are saying just times or division
View attachment 259237 had to make times not division
If you have a decimal fraction and you want a percentage: Multiply by 100.
Example: 0.5 x 100 = 50%
If you have a percentage and you want a decimal fraction: Divide by 100.
Example: 50% / 100 = 0.5
Yes @DaveC426913 gave the pie as an example and that is easiest to visualise and I would use that for fractions then play with numbers going from fractions to % and back.
yes that s what I wanted but didin t know it will work when you multiply a multiple of percentage values .
