Tension and speed at different points of a swinging pendulum
- Thread starter Helly123
- Start date
48 replies · 5K views
Helly123
- 581
- 20
BvU said:Number 3 first. Write down clearly your energy conservation equation.
This how i did it https://s4.postimg.org/ta19uxcz1/image.jpg
Homework Helper
- 16,220
- 4,934
Unconventional presentation, but (quite !) good. So, on to number (5):
##mv^2\over r## of tension is needed to maintain the circular motion.
Once the component of ##mg## along the wire exceeds ##mv^2\over r## the circular motion is interrupted. This happens somewhere between B and D, at a height above C.
Introduce some coordinate, e.g. ##\theta## and work out ##v(\theta)## and from that ##T(\theta)##.
Helly123
- 581
- 20
thanks Sir. that's the most effective way for me to fulfill your order. btw, on number 3-3 I set KE for D negative, because it goes to the left. is that ok??BvU said:Unconventional presentation, but (quite !) good. So, on to number (5):
Homework Helper
- 16,220
- 4,934
That's what I get for looking at the answers too summarily. Sorry.
No. Kinetic energy is never negative (*). The potential energy at D is not ##mg(2b-a)## but ##mg(a-2b)## because the height at D is lower than the height at A.
Both ##m## and ##v^2## are non-negative. For kinetic energy there is no direction, so 'because it goes to the left' does not apply.
Helly123
- 581
- 20
ok somehow maybe I understand. i'll try again thenBvU said:That's what I get for looking at the answers too summarily. Sorry.
Helly123
- 581
- 20
Helly123
- 581
- 20
How do you know its above height C when mg exceeds mv^2/R ? And can you give me another hint to work on tetha to find v?
- 42,954
- 10,553
Draw a free body diagram with the mass somewhere between heights C and D, string still taut. Let the string make angle theta to the vertical here.Helly123 said:How do you know its above height C when mg exceeds mv^2/R ? And can you give me another hint to work on tetha to find v?
What is the speed of the mass, as a function of theta?
Write the ΣF=ma equation for the vertical direction.
Helly123
- 581
- 20
How if i used ΣF = ma on horizontal? Or i make all force in tetha direction?haruspex said:Draw a free body diagram with the mass somewhere between heights C and D, string still taut. Let the string make angle theta to the vertical here.
- 42,954
- 10,553
Yes, sorry, that's better. ΣF=ma along the direction of the string.Helly123 said:Or i make all force in tetha direction?
Helly123
- 581
- 20
But I am confused little bit. Let's say i make SigmaF = ma isharuspex said:Yes, sorry, that's better. ΣF=ma along the direction of the string.
T + mg.cos tetha - centrifugal force = m.a
T + mgcos tetha - mv^2/R = m.a
There's only 1 equation.
To find v and T (2 variables) at least i should have 2 equations..
- 42,954
- 10,553
You can choose to work in an inertial frame or in the frame of reference of the mass.Helly123 said:T + mg.cos tetha - centrifugal force = m.a
In the mass' frame of reference, there is centrifugal force but the acceleration is, by definition, zero.
In the inertial frame, there is no centrifugal force but there is centripetal acceleration, i.e., the component of the resulting acceleration that is normal to the velocity.
The two equations that result are the same.
Helly123
- 581
- 20
haruspex said:You can choose to work in an inertial frame or in the frame of reference of the mass.
For example i used frame of reference of the mass. SigmaF = m.a
When starts to bend, means T = 0? You said a = 0. Why a zero?
So, W - Centrifugal f = 0
M.g - m.v^2/R = 0
gR = v^2
V = sqrt g(a-b)
V = sqrt g(1/2a)
The right answer is sqrt g(1/3a)
What's wrong??
- 42,954
- 10,553
In the frame of reference of the mass, the mass is stationary.Helly123 said:Why a zero?
What happened to cos theta? You had that in post #42.Helly123 said:M.g - m.v^2/R = 0
Helly123
- 581
- 20
Mgcos tetha - m.v^2/R = 0haruspex said:In the frame of reference of the mass, the mass is stationary.
Costetha gR = v^2
V = sqrt g(a-b) cos tetha
V = sqrt g(1/2a) cos tetha
But still...
The right answer is sqrt g(1/3)
Helly123
- 581
- 20
For inertial force, there's centripetal force? Can you give me hint how to work using inertial force?haruspex said:You can choose to work in an inertial frame or in the frame of reference of the mass.
- 42,954
- 10,553
No. When the angle is theta, how far is the mass above the peg? How far below point A does that make it?Helly123 said:V = sqrt g(a-b) cos tetha
Centripetal force is not an actual applied force, like gravity or tension. It is merely that component of the net force which is normal to the velocity. It produces the radial acceleration.Helly123 said:For inertial force, there's centripetal force?
In the vector equation ##\Sigma \vec {F_i}=m\vec a##, we can split the acceleration into the tangential acceleration (the component parallel to the velocity vector) and the radial acceleration (the component normal to the velocity): ##\Sigma F_i=m\vec {a_t}+m\vec {a_r}##. The centripetal force is ##m\vec {a_r}##.
Helly123
- 581
- 20
After a week i finally solved this question. Thanks for all your help guys!
Pendulum Speed at Different Heights
- xasuma
- · Replies 5 ·
- Introductory Physics Homework Help
- Replies
- 5
What is the velocity of the swinging pendulum?
- thakkar1016
- · Replies 5 ·
- Replies
- 5
What is the speed and angle of a swinging pendulum?
- Ready2GoXtr
- · Replies 9 ·
- Replies
- 9
How to Calculate Speed at Different Points Using Conservation of Energy?
- Peterson
- · Replies 3 ·
- Replies
- 3
What is the Force and Speed at Different Points on a Rollercoaster?
- Jacobpm64
- · Replies 3 ·
- Advanced Physics Homework Help
- Replies
- 3
