How Do You Solve Exponential Equations with Different Bases?
  • Thread starter Thread starter johnsonjohn
    Base Log
19 replies · 4K views
johnsonjohn
(1/25)^x+3=125^x+3
I have used log on both sides but keep getting an incorrect answer.
How would solve this type of equation. I set the bases both to 5, make them equal to each other and i can't get the right answer.
Is the + 3 in the exponent? If not you can substract it from both sides.
If the exponent DOES include the + 3 , then the whole exponent should be enclosed in parentheses.
We follow standard Order of Operations here at PF .
yes the +3 is in the exponent. So i should put the whole thing in parentheses.
Make the substitution k = x + 3, then take the log of both sides.
what is k. Is that the (1/25)?
So the equation is:
(1/25)^(x+3) = 125^(2x) ?
EDIT: The equation you initially posted seems to be not the same as the one you wrote down here. Never mind what I said about substitution.
Math_QED said:
So the equation is:
yes that is the equation my apologies.
johnsonjohn said:
(1/25)^x+3=125^x+3
A company is valued at 5 million when first starting, one year later it is at 25 million. Write an exponential equation and find when it will reach 200 million value.
johnsonjohn said:
here a link to it.
Https://imgur.com/oPPO9zT
What you wrote in the first post is different from the image in your later post.
The equation apparently is ##(\frac 1 {25})^{x + 3} = 125^{2x}##
Link to our LaTeX primer: https://www.physicsforums.com/help/latexhelp/
the equation (1/25)^(x+3)= 125^2X that's the equation on the paper.
sorry i didnt click on the link before i replied i will use the Latex thing next time.
Regarding your equation. You must have seen that 1/25 and 125 can be written as 5^(-2) and [itex]5^3[/itex]
Rewrite your equation with this. Post what you get then.
If you write expression in that "in-line" sort of format, please use adequate parentheses.
For example:
(1/25)^(x+3)= 125^(2x)​
I make it 5^(-2)(X+3)=5^(3)(2x) and this is where I think I mess up. I multiply the numbers in parentheses
Now use: [itex](a^b)^c[/itex] = a^(bc)
johnsonjohn said:
I make it 5^((-2)(X+3))=5^((3)(2x)) and this is where I think I mess up. I multiply the numbers in parentheses
f(x) = 5x is a one-to-one function.
Therefore, just equate the arguments of the two sides.
Sorry for starting up this thread again, but what do I put in that equation. Like is 5=A, I don't understand what numbers to plug in.
You can ignore that. Once you have the expression in #16, you can say make an equation where you say the exponents are equal. (Do in fact you take the 5 bases log of what's left and right from the equality sign. Once you do that, you get an easy equation in x to solve. Let us know when you found the answer :)
Yes, but incorporating the extra necessary parentheses as SammyS corrected for you in post #18.
➫ Please apply more care in your future threads. Careless mistakes and omissions in presentation don't give confidence that you are valuing the assistance of forum helpers.
