How Do You Solve Exponential Equations with Different Bases?
  • Thread starter Thread starter johnsonjohn
    Base Log
The discussion revolves around solving the exponential equation (1/25)^(x+3) = 125^(x+3), focusing on the challenges of working with different bases and the implications of the exponent structure.
  • Participants discuss the correct interpretation of the equation, particularly the placement of the +3 in the exponent. There are attempts to rewrite the bases in terms of a common base (5) and to apply logarithmic properties. Some participants suggest using substitutions to simplify the equation.
The discussion is ongoing, with various interpretations of the equation being explored. Participants are providing guidance on rewriting the equation and equating exponents, but there is no explicit consensus on the next steps or a solution path.
There are indications of confusion regarding the original equation and its representation, as well as the need for clarity in notation. Participants are encouraged to use LaTeX for better expression of mathematical ideas.
johnsonjohn
(1/25)^x+3=125^x+3
I have used log on both sides but keep getting an incorrect answer.
How would solve this type of equation. I set the bases both to 5, make them equal to each other and i can't get the right answer.
Is the + 3 in the exponent? If not you can substract it from both sides.
If the exponent DOES include the + 3 , then the whole exponent should be enclosed in parentheses.
We follow standard Order of Operations here at PF .
yes the +3 is in the exponent. So i should put the whole thing in parentheses.
Make the substitution k = x + 3, then take the log of both sides.
what is k. Is that the (1/25)?
So the equation is:
(1/25)^(x+3) = 125^(2x) ?
EDIT: The equation you initially posted seems to be not the same as the one you wrote down here. Never mind what I said about substitution.
Math_QED said:
So the equation is:
yes that is the equation my apologies.
johnsonjohn said:
(1/25)^x+3=125^x+3
A company is valued at 5 million when first starting, one year later it is at 25 million. Write an exponential equation and find when it will reach 200 million value.
johnsonjohn said:
here a link to it.
Https://imgur.com/oPPO9zT
What you wrote in the first post is different from the image in your later post.
The equation apparently is ##(\frac 1 {25})^{x + 3} = 125^{2x}##
Link to our LaTeX primer: https://www.physicsforums.com/help/latexhelp/
the equation (1/25)^(x+3)= 125^2X that's the equation on the paper.
sorry i didnt click on the link before i replied i will use the Latex thing next time.
Regarding your equation. You must have seen that 1/25 and 125 can be written as 5^(-2) and [itex]5^3[/itex]
Rewrite your equation with this. Post what you get then.
If you write expression in that "in-line" sort of format, please use adequate parentheses.
For example:
(1/25)^(x+3)= 125^(2x)​
I make it 5^(-2)(X+3)=5^(3)(2x) and this is where I think I mess up. I multiply the numbers in parentheses
Now use: [itex](a^b)^c[/itex] = a^(bc)
johnsonjohn said:
I make it 5^((-2)(X+3))=5^((3)(2x)) and this is where I think I mess up. I multiply the numbers in parentheses
f(x) = 5x is a one-to-one function.
Therefore, just equate the arguments of the two sides.
Sorry for starting up this thread again, but what do I put in that equation. Like is 5=A, I don't understand what numbers to plug in.
You can ignore that. Once you have the expression in #16, you can say make an equation where you say the exponents are equal. (Do in fact you take the 5 bases log of what's left and right from the equality sign. Once you do that, you get an easy equation in x to solve. Let us know when you found the answer :)
Yes, but incorporating the extra necessary parentheses as SammyS corrected for you in post #18.
➫ Please apply more care in your future threads. Careless mistakes and omissions in presentation don't give confidence that you are valuing the assistance of forum helpers.
