How Do You Solve Second Order Partial Derivatives at Critical Points?
9 replies · 2K views
astenroo
Let f(x,y)= 8x[tex]^{4}[/tex] + y[tex]^{4}[/tex] -2xy[tex]^{2}[/tex], what is [tex]\partial^{2} f[/tex]/[tex]\partial x^{2}[/tex] and [tex]\partial^{2} f[/tex]/[tex]\partial y^{2}[/tex] for the points where [tex]\partial f[/tex]/[tex]\partial x[/tex] = [tex]\partial f[/tex]/[tex]\partial y[/tex] = 0?
The first partial derivative with respect to x: is 32x[tex]^{3}[/tex] - 2y[tex]^{2}[/tex]
and the second with respect to x is: 96x[tex]^{2}[/tex]
The first with respect to y is: 4y[tex]^{3}[/tex] - 4xy
The second with respect to y is: 12y[tex]^{2}[/tex] - 4x
And this is where I get stuck. I have no clue of how to continue from here, and I have tried to find rules for this kind of operation in Boas Mathematical methods in the physical sciences... Maybe I have the wrong literature...
You found
[tex]\frac{\partial f}{\partial x} = 32x^3-2y^2, ~\frac{\partial f}{\partial y} = 4y^3-4xy.[/tex]
Can you find the points where they are both zero?
fzero said:
You found
This is actually where I got stuck. I should put them both equal to zero, and i believe i would end up with an equation system with two unknowns?
but solving for either seems to be a bit complex...
So, no. I can't find the points where they are both zero. Not without help.
So we got the system
[tex] \left\{ \begin{array}{l}<br /> 16x^3=y^2\\<br /> y^3=xy<br /> \end{array}\right.[/tex]
If y is zero, then from the first equation follows that also x is zero. So (0,0) is a solution.
If y is nonzero, then we got the equation
[tex] \left\{ \begin{array}{l}<br /> 16x^3=y^2\\<br /> y^2=x<br /> \end{array}\right.[/tex]
So we have that [tex]16x^3=x[/tex]. This gives us x=0 or x=1/4 or x=-1/4. You can now easily see what the corresponding y-values are.
Ouch...yep, needed to sleep on it. I recently came up with a similar solution. Thank you very much for the help.
Ok so here goes, if x=0, then y=0 (0;0)
if x=.25, then y=.5 or -.5 (both satisfy the equations) (0.25;-0.5) and (0.25;0.5)
if x=-.25, then y=has only imaginary (or is it complex?) solutions.
For the y''=96x^2=0 for (0;0) and y''=6 if x=0.25
For the other partial:
12y^2-4x= 0 at (0;0)
12y^2-4x=2 at (0.25;0.5)
12y^2-4x=2 at (0.25;-0.5)
Can someone confirm this for me?
micromass said:
Seems alright...
Thank you very much for your help. This is one the best forums ever :)
