How Do You Solve These Newton's Law Problems?
19 replies · 6K views
ramenluver50
1)The particle shown below is at rest, where F = 65.0 N, and θ = 33.1°. Find the magnitudes of F1 and F2.
2)Just after opening a parachute of negligible mass, a parachutist of mass 99.5 kg experiences an instantaneous upward acceleration of 1.09 m/s2. Find the force of the air on the parachute.
-specifically magnitude
3)Find the tension in each string in the figure below, where θ1 = 41.0°, θ2 = 20.5°, and w = 28.0 N. for t1, t2, and t3
F=ma
i don't know...
for the X and y for just F, i used sin 33.1=X/65 and for Y used cosine, but that's about the farthest I've went.
right, so if the particle is at rest, meaning it is in equilibrium, what should the resultant force be horizontally and vertically?
i think horizontal, but I am not sure
yes, where there is balance
Right! So considering the x-direction, if there is balance, then shouldn't the forces point to the left be equal to the forces pointing to the right?
Similar for the y-direction.
so your saying if i just find the X and Y for F they X and Y should be the same force equivalence to F1 and F2? , i tried for X where sin 33.1=X/65, and X would be 35.5, apparently the answer is incorrect.
EDIT:*******
sorry, you are right, i entered the answer in the wrong answer slot, haha.. thx
EDIT:*******
Now try the second and third problems.
for Number 2,
i used the F=ma formula, where, 99.5 (1.09) to get the Newtons of 108, which is wrong...for #3, i got T3 which is 28 N, but for T1 and T2, do i just used T3 as the vertical measurement to find T1 and T2 ?
ramenluver50 said:
for Number 2,
108 is the resultant force on the body, what other forces are acting on the body?
Yes, that should work.
2) there is also gravity,not sure what to do with it though,
3) i did sin 41=28/T1 which gave me 42.6 , that isn't right bc its force is larger... :-/
There is the force of gravity and what other force? (they asked you to find this force)
You have T1 and T2 acting at their respective angles. These two force both have components in the x and y directions. What are these components? If the figure is in equilibrium, the sum of forces in any direction is ?
thx i got number 3 down,
the other resistance for number 2 is air...
Good, so what directions do the weight and the force of air act?
wieght is downward force, and air is up...
Then what would be an expression in terms of these two for the resultant force?
A force is a vector quantity,
which means it has a magnitude and a direction,
in your first question you are given the magnitude of the force = 65 N and the direction to be 65degrees
in the x&y direction
you can separate this force into the two forces that make that force i.e
[tex]Ftotal = Fxdirection + Fydirection[/tex]
but you're probably wondering how you get the force in the X direction from the total force?
use trigonometry , that is your F total to be the hypotenuse, Fx to be your adjacent, and Fy to be your opposite
just use basic trigonometry to figure fx and fy out
and you know that the particle is at rest,
so f1 must = -fx
and f2 = -fy
otherwise the particle would start moving!
