What Determines the Existence of Solutions for Quadratic Residues Modulo N?
  • Context: Undergrad
  • Thread starter Thread starter jostpuur
The discussion focuses on determining the existence of solutions for the equation y = x² mod N, where N is a positive integer. It highlights that for N=5, solutions exist for y=0, 1, and 4, but not for y=2 or 3. The conversation emphasizes that for prime N, there is a specific algorithm to identify quadratic residues, and mentions Euler's criterion as a method to verify if a given k is a solution for k ≡ x² mod p, where p is prime.
  • Understanding of quadratic residues and nonresidues
  • Familiarity with modular arithmetic
  • Knowledge of Euler's criterion for quadratic residues
  • Basic concepts of prime numbers and their properties
  • Study algorithms for finding quadratic residues for prime numbers
  • Explore the implications of Euler's criterion in number theory
  • Investigate the behavior of quadratic residues modulo composite numbers
  • Learn about the properties of quadratic residues in different mathematical contexts
Mathematicians, number theorists, and students studying modular arithmetic and quadratic residues will benefit from this discussion.
jostpuur
Suppose N=1,2,3,\ldots and y=0,1,2,\ldots, N-1 are fixed. How do solve x out of
<br /> y=x^2\quad \textrm{mod}\quad N ?<br />
I went through some of the smallest values for N and all y, and I could not see a pattern. For example, if N=5, then at least one [x] exists if [y]=[0],[1] or [4], but no solution [x] exists if [y]=[2] or [3]. You can produce similar result for other small N with finite amount of work, but I failed to see a pattern that I could try to generalize.
Mathematics news on Phys.org
For prime N, there is an algorithm. The article also has a link for the other cases.
You're talking about quadratic residues.
Modulo 2, every integer is a quadratic residue.
Modulo an odd prime number p there are (p + 1)/2 residues (including 0) and (p − 1)/2 nonresidues. In this case, it is customary to consider 0 as a special case
Edit to add: If you just want to determine whether a given k is a solution to ##k \equiv x^2 \text{ mod } p##, for ##p## prime, you can use Euler's criterion: ##k^\frac{p-1}{2} \equiv 1 \text{ mod } p##
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 25 ·
