How do you trace through a recursive method in Java?
  • Topic: Java
  • Thread starter Neon32
    Java tracing
12 replies · 3K views · last reply
Neon32
It would be much appreciated if you could show me how to do recursive tracing for this method.
Java code for a recursive method named mystery(int n), with the if (n/2 == 0) line and the else-if branch where n % 2 == 0 calls mystery(n - 1), then prints n, parentheses and plus signs.
What's recursive in this method ?
Did you try typing it in and see what it does ?
Is this homework ?
Is this homework ?
1) mystery(n-1) is recursive
2) No it isn't homework. I'm studying for my exam
I see. Maybe I misunderstand 'recursive' : I then expect a call to 'mystery' inside the method. Don't see one, so your idea of recursive is something else. Can you explain ?
Must be blind. Sorry.
All I've left is question 2 :smile:
Yes I've tried to trace it and all I got was (6 + ((4 + ((2 + . I don't understand how to continue it.
I get
Code:
 ----- 6 ----------
(6 + ((4 + ((2 + ( 0
 + 1)
 + 3)
 + 5)
when I input the number 6 in :
Code:
Sub mist(n As Integer)
    If n / 2 = 0 Then
        Debug.Print n
    ElseIf n Mod 2 = 0 Then
        Debug.Print "(" & n & " + ";
        mist n - 1
        Debug.Print ")"
    Else
        Debug.Print "(";
        mist n - 1
        Debug.Print " + " & n & ")"
    End If
End Sub
Sub test()
Dim n As Integer
again:
    n = CInt(InputBox("Give n "))
    Debug.Print "  "
    Debug.Print " ----- " & n & " ---------- "
    If n < 0 Then Exit Sub
    Call mist(n)
    Debug.Print " -------------------------- "
    GoTo again
End Sub
No. The mystery() function is recursive because it calls itself.
BvU didn't ask about tracing the function; he asked if you had tried typing it in and running it. Seeing what the function produces might be helpful in understanding what it does.
I am not fluent in Java. I find 1 / 2 is integer division and yields zero, so in the context of Myst "if N/2==0" is equivalent to " if n= 1" in VB.
If I take that into account the 0 goes away.
(and if I add some ; at the end of the print statements it all ends up on one line:
Code:
 ----- 6 ----------
(6 + ((4 + ((2 +  1 ) + 3)) + 5))
Wonder why your routine doesn't render the odd numbers ...
Excel VBA is easy with its debugger at hand.
Don't know what Java has for you. If no debugger, then perhaps some more print statements ?
There's a systematic way to find out the tracing for any recursive method like trees method or in a table or whatever. I want to know the method you used to find out the tracing not the final answer. My exam is in paper so I won't have jcreator or VBA during the exam xD
Didn't know that; was just trying to help. My systematic method has always been trial and error :rolleyes: -- especially the latter.
Good luck with your exam !
Thank you :).
