How Does a 0.0200-kg Rock Accelerate When Shot Upward with 98.0 N?
  • Thread starter Thread starter andrewy77
    Acceleration Rock
The problem involves a 0.0200-kg rock that is shot upward with an average force of 98.0 N, and it accelerates through a distance of 0.150 m. Participants are exploring the dynamics of forces acting on the rock, particularly in relation to its acceleration and the effects of gravity.
  • Participants discuss the forces acting on the rock, questioning whether the 98.0 N force is the net force or the applied force alone. There is an exploration of the relationship between force, mass, and acceleration using Newton's second law.
Some participants have provided guidance on using free body diagrams and the formula F = ma to find acceleration. There is ongoing clarification regarding the interpretation of the given force and its implications for calculating net force and acceleration.
Participants note that the problem does not explicitly state whether the 98.0 N force includes the effects of gravity, leading to different interpretations of how to approach the calculations.
andrewy77
A 0.0200-kg rock is shot directly upward with an average force of 98.0 n. The rock accelerates through a distance of 0.150 m.
a.) Determine the acceleration while in the slingshot.
b.) What is the velocity with which it leaves the slingshot?
c.) What force acts on the rock after it leaves the slingshot and what is its value?
d.) What is the value of the acceleration/deceleration after it leaves the slingshot?
e.) How far upward does it travel before it begins to fall?
f.) How long is the rock in the air upon returning to the level of the slingshot?
I've tried v= v0+ at for part a; however, my Physics teacher said I was so wrong. Could you help with with this problem? I've tried everything, and I can get the rest of the worksheet. It's just this problem that makes my head spin around like Linda Blair...
Thanks so much and have a great day! :)
Andrew
Hi Andrewy77. Welcome to Physics Forums.
What forces are acting on the mass? What's the total force? What's the formula for acceleration given total force and mass?
Thanks for the greeting!
The problem doesn't say; therefore, I think the only force acting on it is gravity, which is 9.8 m/s.
Well, given that m= f/a
a= f/m. That is all the information he gave us.
Andrew
Newton's Laws; specifically the second.
F = ma is what you are after - you have the force, you have the mass, you can find the [average] acceleration.
Did you draw a Free Body Diagram for the rock while it's in the slingshot?
Yes; the diagram helped a little.
For part a), I used f=ma
Solving for a gets you a=f/m
With the given data, I got 4900 m/s for a. That sounds a little quirky..
Looks like a plausible acceleration for such a small mass. However, I have one question that should be decided before you proceed: Is the given 98.0N force the net force on the stone including the effects of gravity (weight), or is it the average force applied by the slingshot alone? If its the latter case, then the actual acceleration will be reduced by g.
Well, the problem states the rock was shot with 98.0 n of force, so I'm guessing it's the force applied to shoot the rock.
If that is the case then subtract g from the acceleration you calculated above:
[tex]a = \frac{f_{net}}{m} = \frac{F - m g}{m} = \frac{F}{m} - g[/tex]
  • · Replies 17 ·
  • · Replies 20 ·
10K
14K
