How Does a Bullet Impact Affect the Angular Velocity of a Door?
  • Thread starter Thread starter sp3sp2sp
    Bullet
3 replies · 4K views
sp3sp2sp
A 10 g bullet traveling at 370 m/s strikes a 8.0 kg , 0.80-m-wide door at the edge opposite the hinge. The bullet embeds itself in the door, causing the door to swing open.
What is the angular velocity of the door just after impact?
Express your answer to two significant figures and include the appropriate units.
use conservation of momentum for slab about edge: linear momentum = angular momentum
mv = Iw
I = (1/3)ML^2 (for a slab)
w = (3mv) / (ML^2)
(w = omega)
3. The Attempt at a Solution
w = (3mv) / (ML^2)
w = (3* 0.01kg * 370m/s) / (8.0kg * 0.80kg^2)
w = 2.167 = 2.2 rad/s
= wrong
cant see what I am doing wrong, thanks for any help
o_O
Linear momentum and angular momentum are different quantities with different units. They cannot be set equal. In this case, only one of those is conserved.
Hint: Use conservation of angular momentum. (What's the angular momentum of the bullet just before impact?)
bullet doesn't have any angular momentum before impact So Iw = 0?
