How Does a Line Intersect with Planes in Vector Geometry?
  • Thread starter Thread starter otterandseal1
    Planes Vectors
11 replies · 2K views · last reply
otterandseal1
I'm struggling to get part b. I got part a to be (1,4,-1). Just got no clue for b. Pls help
Dont know what to put here
Printed exam question 11 with parts (a) to (c) on lines and planes: find where the line (x+2)/3 = y/4 = (z-1)/-2 meets the plane 2x - y - 3z = 1; show the plane through that line perpendicular to the plane 2x - y - 3z = 1 is 14x - 5y + 11z = -17; find the line of intersection of the two planes. Marks 4, 3 and 3 shown.
otterandseal1 said:
Homework Statement:: I'm struggling to get part b. I got part a to be (1,4,-1). Just got no clue for b. Pls help
Relevant Equations:: Dont know what to put here
Can you find a normal to ##\pi_1##? You should be able to do this by inspection from its equation. Also, if two vectors are perpendicular, their dot product is 0.
Is the normal (2,-1,-3)?
Yes.
You can find the normal of the other plane if you know two vectors the plane contains.
ehild said:
Yes.
is that using r.n = a.n ?
If ##\vec a## and ##\vec b## are vectors that lie in the plane you're trying to find the equation of, then ##\vec a \times \vec b## gives you a normal to that plane.
Could you possibly show me the working for the question please?
No, can't do that, per the forum rules. See https://www.physicsforums.com/threads/physics-forums-global-guidelines.414380/, under Homework Guidelines.
Can you find two vectors in the plane you're trying to find?
If so, can you find their cross product? That will give you a normal to that plane. Once you have the normal, all you need is a single point in the plane, and you can find its equation.
Could I use the vector from part a? and the normal of the first plane?
What vector do you mean? And, yes. as the two planes are perpendicular the second plane contains the normal of the first plane.
Where the line meets the first plane
No, it is a point , common point of the first plane an the line I. P (1,4,-1) is the position vector a of this point, it does not lie in the plane as vector b. But the line I lies in the second plane and so is its direction vector. What is it?
3D diagram of a plane drawn as a parallelogram, with point O below it, point P on the plane, vector a drawn from O to P, and vector b shown as an orange arrow lying within the plane.
