How Does an Electric Field Affect Energy Levels in a Quantum Well?
Cerkit
Hi. Does anyone know how to perform perturbation theory for a finite well under the influence of an electric field?
If not or also what other method is there to calculate the shift in subband energies under the influence of an E field in a quantum well?
Thanks
The very first treatments of the QCSE were performed with variational methods, see for example:
"Band-Edge Electroabsorption in Quantum Well Structures: The Quantum-Confined Stark Effect" by Miller et al. (Phys. Rev. Lett. 53, 2173–2176 (1984)) or the more detailed follow-up paper "Electric field dependence of optical absorption near the band gap of quantum-well structures" also by Miller et al. (Phys. Rev. B 32, 1043–1060 (1985)).
A perturbation approach is given in "A Semi-Empirical Model for Electroabsorption in
GaAsIAlGaAs Multiple Quantum Well Modulator Structures" by Lengyel et al. (IEEE J. Quantum Electron. 26 (1990), p. 296.).
Ok. Well as of now I have read through the variational method. I have also found a variational method for a triangle potential well but that is for an infinite well. The only explicit variational method I have found for a finite well is G.Bastard, E.E. Mendez ,Variational calculations on a quantum well in an electric field but the problem with that is that it only gives the calculations for weak fields and says that the expectation values of the hamiltonian for strong fields is not shown because it is too complicated. I am trying to find a fairly simple method which can account for both weak and strong fields. In general I just need an approximation to the perturbation/difference in the energy levels.
Also does anyone have any idea what kind of accuracy can be obtained through using infinite well approximation rather than the finite one?
Just do the math, its not that bad. You find the unperturbed wavefunction and calculate first order shift in energy as usual.
Which method do you advise me to use as a first timer. Perturbation theory apparently doesn't account for strong fields...?
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
