How does an isolated observer know if they're accelerating?
  • Level: High School
  • Thread starter Thread starter Shirish
    Accelerating Observer
84 replies · 8K views
hutchphd said:
Can one not use two clocks, separated but stationary with respect to the observer as an accelerometer? Any change in the synchrony of the clocks will indicate an acceleration.. (?)
Which observer do you mean? One who accelerates stationary with the clock or an inertial observer?
A.T. said:
That is true in Newtonian physics. In General Relativity inertial frames where refined to always match zero accelerometer reading.
Could you elaborate? If we calibrate the accelerometer in an inertial frame, and if inertial frames are frames where the accelerometer reading is always zero, won't that be a circular argument? At some point we'll have to make an assumption / axiom and let everything follow from that - but I'm not sure what's an axiom and what's a consequence. So could you explain how the case is different in general relativity from special relativity/Newtonian mechanics in this context?
I'm afraid I'm getting in the middle...thought the main question was answered.
I mean the guy has a clock in each of spread-out arms. My tenet is that this serves as an accelerometer along the direction of his arms. ... the clocks will immediately change synchrony with any acceleration. No other frames required, just the guy and his clocks , simple question as sanity check for me..
Shirish said:
If we calibrate the accelerometer in an inertial frame...
An ideal accelerometer is a box containing a weight; the weight is attached by six stretched strings to the six sides of the box. Proper acceleration is measured by the tension in the springs, which in turn is calculated from the stretched length of the springs and Hooke's Law.
This accelerometer needs no calibration; the proper acceleration is zero if and only if the tension of each spring is equal to the tension of the opposite spring.
It depends on your orientation relative to your acceleration. If your proper acceleration is along your feet to head axis, and your hands are outstretched, there will be no change in the comparison of the clocks. If you hold one clock down towards your feet, and one above your head, their synchrony will change.
They aren't. Inertial frames are frames in which the reference clocks and rulers we use to measure times and distances are in free fall. But that doesn't mean every single object in the universe needs to be in free fall. You can still apply forces to objects, such as accelerometers, and measure their effects. So you can still calibrate an accelerometer in an inertial frame.
@Shirish now you've got dragged into trying to understand GR before you can even start to learn SR!
You're right! Baby steps - my bad
I would say that there are several equivalent tests for whether a frame is inertial or not.
In principle an accelerometer does not need calibration because they are based on defined measurable local effects. Of course, in practice many accelerometers need to be calibrated to get the most accurate reading, but that is not an “in principle” problem.
In a gravitational field it becomes fairly easy to calibrate using an accurate ruler and clock and a free falling object. That is an in principle circular approach (how do you know the object is in free fall), but not a practical problem (we know how to build one pretty well).
I should probably note that many of the concerns in this thread disappear with the idea of arbitrary coordinate systems. The underyling philosophy is that coordinates are just labels. It takes a bit of extra work to formulate physics in a way that allows this to happen, Lagrangian mechanics is an example of how to do this. You'd start with lumped Lagrangian mechanics, then go to Lagrangian field theories. Goldstein covers this in the graduate text "Classical Mechanics".
Another thing that's worth pointing out is that the offered defintions of proper acceleration as inpired by GR do not include gravity as a force. Therefore, for instance, if you are riding on one of the "zero-G" aircraft flights, the so-called "Vomit comet", and your stand on a scale, it reads zero, and by the defintions being discussed you are not accelerating, as your proper acceleration is zero. Newtonian gravity does things a bit differently, but we already know it's not as good as GR as far as experiment goes, though it's often close enough and it's considerably easier to calculate with.
Shirish said:
...if inertial frames are frames where the accelerometer reading is always zero, won't that be a circular argument? ...
It's not an argument, but a definition. In inertial frames of GR accelerometers at rest read zero.
In GR context, does that imply that free falling reference clocks and rulers we use (to measure times and distances) might be not at rest with each other ?
In curved spacetime there are no global inertial frames, only local ones. In local inertial frames the reference clocks are at rest wrt each other to first order.
Yes. Consider two free-falling parachutists on opposite sides of the earth. Both are in free fall, but also moving towards one another so not at rest relative to one another.
The easiest way to determine if your accelerating is to make a simple pendulum. IF the pendulum makes some angle with the vertical then your accelerating. In other words your frame of reference is one which is non inertial ( provided there is some deflection.)
This is not correct.
If there is a particular "vertical" direction in your vicinity, that will in general be the direction of your acceleration, and a hanging pendulum will align itself along this direction.
if your located on the Earth, moving in a horizontal direction and accelerating along this direction then the pendulum will make some angle since the horizontal component of the tension force ( string of the pendulum) will be unbalanced
That's not an isolated observer, then. That's someone who can see a planet out of their window. And with this scheme you are measuring coordinate acceleration, not proper acceleration, because you are comparing an instrument reading (the direction of the pendulum) to a standard (what you are calling vertical) which you cannot justify without reference to an outside body (the planet). Furthermore, your scheme is blind to the case that your proper acceleration is parallel to the direction you are calling vertical.
It is not too far off though. If there is a “vertical” at all then the pendulum is non inertial. So the device @hot pies described can indeed be used as a simple accelerometer.
Not in the mode of operation he's proposing, though, at least not for an isolated observer. I agree you could use a pendulum by simply displacing it from whatever position it's in and seeing if it starts to return - a minor modification of the standard way of measuring ##g## with a pendulum.
If this is a pendulum on a fixed axis (one degree of freedom) one needs to find three suitably independent directions. If the pendulum stays put in all three directions, there is no proper acceleration.
If this is a pendulum on a ball joint or similar (two degrees of freedom) then one need only find two distinct directions that are not at 180 degrees to each other. If the pendulum stays put in both directions, there is no proper acceleration.
One observes that the pendulum, when it does not stay put, follows an oscillating pattern. [If not, the proper acceleration is not constant and will be tough to quantify]. If so, the midpoint of the oscillation is determined by the direction of the proper acceleration. In the fixed axis case one needs readings from two axes.
With the direction of acceleration determined, one can set up small oscillations and measure the magnitude in the obvious manner.
Some angle with what? If you are accelerating horizontally, the direction you think is "vertical" will change. The pendulum will point in the direction you now think is "vertical".
If you have some external reference other than your own acceleration, you can tell the difference between that external reference's "vertical" and the "vertical" defined by your acceleration. But this thread is about an isolated observer, who has no such external reference.
I have another small clarification related to inertial / non-inertial frames - just want to be doubly sure about it.
Imagine a person and a weighing scale accelerating through empty space towards each other, with the person being pulled by a downward force F (being exerted by some distant, unknown source S) and the scale being pulled upward by a force of the same magnitude F (being exerted by a different distant and unknown source S ′).
Later they collide and the person ends up standing on the scale, but they stop moving since both are being pulled against each other with the same force F.
In this case, do we say that the person's rest frame (and by extension the scale's rest frame since it's also at rest w.r.t. the person) is inertial or non-inertial?
[My thoughts so far: before hitting the scale, if the person used an accelerometer, he/she would detect an acceleration and conclude his/her rest frame was non-inertial. But after hitting the scale, he/she would no longer be accelerating due to the distant source S, since the force is balanced by the scale pushing against the person. Hence, there will be no reading on the accelerometer and the person would conclude that his/her rest frame is inertial. Am I correct in saying this?]
[Tried asking this on Physics SE: https://physics.stackexchange.com/q...-being-pulled-in-opposite-direction-by-the-s/ but like I said, would be nice to have additional confirmation, plus I don't know if 'space frame' is conceptually correct to talk about]
Yes, that is pretty reasonable. Of course, you do have to be careful like this. In principle a reference frame usually is considered to cover all of spacetime, so you would have to consider the entire worldline (and therefore say it is non inertial).
But if you are careful at the borders it is possible to break your spacetime up into patches and identify specific patches as being inertial or non inertial. There is nothing wrong with that in principle, but in practice many people who do that are not careful about the boundaries and can produce errors that way.
But one of my takeaways from this thread was that the way to determine whether one's rest frame is inertial / non-inertial is by using an accelerometer. So let's say that person after hitting the scale sees no reading on the accelerometer, even in the thought experiment there's no way for him to determine everything globally or the entire worldline, right?
He could carry a recording accelerometer and look at the record.
He could carry a spatially separated set of 4 "synchronized" clocks rigidly attached to his person and look for asynchrony.
What does "everything globally" mean...he will likely not be omniscient! It is not clear what you mean.
Sorry for the vague wording, by that I mean he can only make local measurements. So he'll have to conclude something about his reference frame, that covers all of spacetime, using only local measurements. I'm not sure how
I will defer to @Dale (or anyone else who actually knows!) but given a recording 3D accelerometer I don't know why he cannot always trace a path through spacetime from that data and end points
That can’t be done; he can only verify that he is at rest in a local inertial frame.
