How Does Angular Velocity Change When a Mass on a String is Pulled Inward?
13 replies · 4K views
Astrum
A mass ##m## whirls around on a string which passes through a ring. Neglect gravity. Initially the mass is at distance ##r_0## from the center and is revolving at angular velocity ##\omega _0##. The string is pulled with constant velocity ##v## starting at ##t=0## so that the radial distance to the mass decreases. Draw a force diagram and obtain a differential equation for ##\omega##
So, the force diagram has only one force, which is the tension on the string acting on the mass. Because the string is shortening by ##v = \dot{r}##, I set up the equation ##T = F_r = m(-r\omega ^2 +r\omega +2v\omega)##
If we divide out ##m## we get ##\mathbf a = -r\omega ^2 +r\omega +2v\omega##, I'm not exactly sure what we're suppose to get on the other side.
I'm asking for a hint, or maybe a word of advice. The book says the answer should be simple and easy to integrate.
Hi Astrum! :smile:
Since you don't know what F is, what is the point of your radial equation?
Try the tangential equation. :wink:​
The dimension of ##r\omega^2## and ##v\omega## is ## m \cdot s^{-2} ##, while the dimension of ## r\omega## is ## m \cdot s^{-1} ##. They cannot be added together.
Is the force-based approach mandatory here? Conservation of angular momentum seems far more suitable here.
That equation is dimensionally incorrect. The mrω term has units of momentum.
And check the sign on ##v = \dot r##.
What is conserved as the string is pulled in?
Yes, this needs to be worked out through using force, rather than conservation of angular momentum.
tiny-tim said:
Hi Astrum! :smile:
I'm not sure what you mean by tangential, are you talking about ##\hat{\theta}##?
##a_r =( \ddot{r}-r\omega ^2 )\hat{r}## and ##a_{\theta} = (r\dot{\omega}+\dot{r}\omega )\hat{\theta}##, these each can be rewritten as ##a_r = -r\omega ^2 \hat{r}## and ##a_{\theta} = (r\dot{\omega}-v\omega)\hat{\theta}##. Are you saying to rewrite these in terms of tangential velocity? I'm not sure how that helps us.
One of the terms has a factor of 2 missing.
Tangential velocity is directly related to angular velocity.
Sorry, I always seem to miss terms when typing them =/
I realize that, ##r\omega = v##. What does this do for us though? All it does is eliminate the very thing we're interested in finding.
I don't really understand the direction you're pointing me in.
Because there's no force in the radial direction, we can say: ##0 = r\dot{\omega}-2v\omega##, if we split it up, we get:
$$ \int \frac{d\omega}{\omega} = -\int \frac{2v}{r} dt$$
:confused:
Since there is no tangential force, what can be said about the tangential acceleration?
Oops, I missed your edit. Use the fact that ## dr = -v dt ##.
Oh, and that minus sign in front of the RHS integral is definitely wrong.
I tried to solve it with respect to ##t##, because that's what we're after, why would be integrate ##r##?
Doing it the way you said, we find ##\omega = r + C##, and that just isn't right.
My attempt is here: Solving this, we end up with $$\omega (t) = ce^{\frac{2v}{r}t}$$, solving for initial conditions: ##\omega (0) = \omega _0 ##, therefore ##\omega (t) = \omega _0 e^{\frac{2v}{r}t}##, this doesn't pass the hint given in the text though, so I'm still missing something.
The hint given says "if ##vt=\frac{r_0}{2}## then ##\omega = 4 \omega _0##. plugging it in we get ##\omega= \omega _0 e^{\frac{r_0}{r}}##"
Judging by how simple this turned out to be, I'm sure there's some little detail I just am not seeing.
Edit: sorry if I'm being sloppy, I'm doing half my work on paper and the other half in the posts, so I may have made an algebra error.
I do not see how you end up with either solution.
Method 1. $$
0 = \int\limits_{\omega_0}^{\omega} \frac {d\omega} {\omega} + 2 \int\limits_{r_0}^{r} \frac {dr} r = \ln \frac {\omega} {\omega_0} + 2 \ln \frac r {r_0} = \ln \frac {\omega} {\omega_0} + \ln \left( \frac r {r_0} \right)^2 = \ln \frac {\omega r^2} {\omega_0 r_0^2}
\omega r^2 = \omega_0 r_0^2
$$ which is conservation of angular momentum, as was to be expected. That cannot possibly give you ## \omega = r + C##.
Method 2, where explicit dependence on ##t## is retained, is similar, keeping in mind that ## r = r_0 - vt ##.
Method 1. $$
I see, that makes a lot of sense. I was under the impression that I didn't need to place limits of integration on there. I'll be sure not to make that mistake again.
Thanks for the help, I made that one way harder than it needed to be.
Personally, I prefer using limits of integration from the beginning and avoid having indeterminate constants of integration. But that is not essential here. You would just get $$
\ln \omega + 2 \ln r = C
\ln \omega r^2 = C
\omega r^2 = k = e^C
$$ which is conservation of angular momentum again.
