- 13,807
- 16,622
I'm allergic to M&Ms, but I'm not surprised it's still done. It's simple and it does bring home why exponential decay is called "memoryless".rsk said:We still do this - sometimes with dice/die, sometimes with m&ms or skittles ;)
Auston Louis said:As a physicist, I'm going to pose a philosophical viewpoint to this whole decay concept. Theoretically, if one started with 1,000 atoms and were able to identify, separate and isolate the 500 atoms that were going to decay sometime within 5700 years, one would end up with the remaining half that would not decay until the 5700 years had expired. Although this challenge has not been attempted yet, it is not really "foolish thinking" because we are applying a perfect "tool," which is a mathematical statistical equation of probability, to a phenomenon of physics, which scientists do not thoroughly understand, (although of course, the tool works quite well). It seems to me, however, that something is changing within the atom, like an internal stop watch, or a clock of sorts, and it is reasonable to assume that an atom that will decay one second from now does not possesses the exact same characteristics or qualities, if you will, as an atom that will not decay for another 5,700 years, or longer. I am proposing that to maintain that these two atoms are identical physically, electromagnetically and in every nuclear-atomic way, is illogical.
One wonders whether this question will ring any Bells...PeroK said:In other words, there must be an internal "hidden" variable. When a Carbon-14 atom is created, there must be an internal timer set to say after how long it will decay?
Auston Louis said:I am proposing that to maintain that these two atoms are identical physically, electromagnetically and in every nuclear-atomic way, is illogical.
If you violate the laws of physics in our universe then you can do whatever you want, but it will have little relevance for the universe we live in.Auston Louis said:Theoretically, if one started with 1,000 atoms and were able to identify, separate and isolate the 500 atoms that were going to decay sometime within 5700 years
You may find that assumption to be implausible, but that's not the same thing as illogical. I'm not sure why you find this assumption to be so implausible though.Auston Louis said:[Hypothetically] if one started with 1,000 atoms and were able to identify, separate and isolate the 500...
Suppose that we program all the coins according to an exponential distribution of flips-until-the-first-tails. And we speculate that the internal timer that is so-programmed is hidden. The only way to query it is to flip the coin until the first tails.Nugatory said:If we don't start with half the coins having N=1, one-quarter N=2, one-eighth N=3 and so forth we won't get results that match the observed results - and the more we try to imagine how that might happen, the more implausible and contrived the idea seems.
Nugatory said:You may find that assumption to be implausible, but that's not the same thing as illogical. I'm not sure why you find this assumption to be so implausible though.
Imagine that we have a large number of coins. We'll call the heads-up state "undecayed" and the "tails-up" state "decayed". Initially they are all in the heads-up undecayed state. Once every minute we toss all the coins into the air so that each one comes down heads-up (undecayed) or tails-up (decayed) with 50% probability. We will find that the half-life of a collection of undecayed coins is one minute; on average half the coins will decay every minute.
We could assume that the process is not in fact random. Maybe each coin contains an internal trigger that counts tosses and cause the coin to land tails after N tosses; if when we start half the coins have N=1, one-quarter have N=2, one-eighth have N=3 and so forth we would see this behavior. Under this assumption, we could in principle identify ahead of time the 500 out of 1000 that will decay during the first half-life as you suggest - they're the ones for which N=1. However, we don't need that assumption to explain the decay behavior; random every toss works just as well and is much more consistent with our understanding of how coin tossing works.
A further difficulty with your seemingly "logical" idea that the decay times come from some internal property of the atoms is that the initial conditions have to be tuned very carefully to match the observed results. If we don't start with half the coins having N=1, one-quarter N=2, one-eighth N=3 and so forth we won't get results that match the observed results - and the more we try to imagine how that might happen, the more implausible and contrived the idea seems.
Look up ROC, Receiver Operating Curve to see relation between sample size and power of the test.kevinmorais said:I Think I get it, this only works for HUGE Amounts of Atoms, if we were to Try and Carbon Date a Sample with only 100,000 atoms half life it wouldn't work...what would be the smallest sample we could carbon date, like how many atoms for the Statistics to work because it has to be large numbers of atoms or we can get the popcorn effect I am only guessing...
You’re proposing that there is an as-yet-undiscovered hidden variable theory (that’s the standard terminology and you’ll occasionally see the acronym HVT) that explains the apparent randomness of quantum mechanics the same way that classical mechanics can in principle explain the apparent randomness of a tossed coin. That is a plausible enough conjecture, and it would not be completely amazing if such a theory were eventually discovered. However...Auston Louis said:My proposal is similar to your analogy of the tossed coins in that there are factors that have yet to be determined, both within the atom awaiting decay and the immediate environment surrounding the atom, that determine if the atom will decay now or in another 5,000 years.
Thanks for your time and insight in assisting me gain an improved perspective of my proposal.mfb said:If you violate the laws of physics in our universe then you can do whatever you want, but it will have little relevance for the universe we live in.
mfb, thanks much for your explanation. How about atoms that are not in the ground state?mfb said:@Auston Louis: It's an analogy, and if you take analogies too far you always end up with wrong results. Coins will never fully simulate quantum mechanics, but something you can take away here: When you have the coins in your hand there is nothing relevant that would distinguish the coins. You can inspect the coins as much as you want, you still can't predict on which side they will land. There is nothing that would make one coin a heads-coin, and in fact if you throw the same coin many times you'll get different results.
All this is not needed in quantum mechanics, where you can show that atoms of the same nuclide in the ground state are exactly identical by observing the statistics they follow.
Nugatory, thanks for your helpful explanations.Nugatory said:You’re proposing that there is an as-yet-undiscovered hidden variable theory (that’s the standard terminology and you’ll occasionally see the acronym HVT) that explains the apparent randomness of quantum mechanics the same way that classical mechanics can in principle explain the apparent randomness of a tossed coin. That is a plausible enough conjecture, and it would not be completely amazing if such a theory were eventually discovered. However...
Bell’s theorem (google, and also look for the web page maintained by our own @DrChinese) and the experiments it motivated shows that any correct hidden variable theory must be at least as weird and offensive to our classical intuition as QM itself. So although you may feel that the random black box model of QM “can’t be right”, you’re not going to like the alternatives any more. In particular, you can’t have a theory that offers the same “if we just knew the exact values of...” certainty that Laplace’s demon promised us and that you’re finding in a tossed coin.
They are different from atoms in the ground state. Nothing mysterious. For nuclear decays this rarely matters.Auston Louis said:How about atoms that are not in the ground state?
Vanadium 50 said:@Nik_2213 , it sounds to me like you are proposing an undetectable flux of an unconfirmed particle is producing an unneeded effect.
I really due care.Nik_2213 said:But, as I cautioned, based on limited data: Due Care, Please ??
As ever, Due Care, Please ??
Auston Louis said:why I believe that two atoms, one that will decay within the next hour and one that will decay in more than 5,000 years are not identical.
+1 on that. I don't understand why this thread is still open.Vanadium 50 said:I'm surprised we are discussing this, since this is pretty clearly a personal theory and we don't discuss that topic here.
Indeed, time to close. Thanks to all that have participated.PeroK said:@Vanadium 50
Maybe we were awaiting the definitive rebuttal, and now that you've provided it the thread can be closed with a flourish!
