How Does cblas_dgemm Handle Matrix Operations in C?
  • Thread starter Thread starter KStolen
The discussion revolves around understanding the cblas_dgemm function from the BLAS library, specifically how it handles matrix operations in C. Participants explore the parameters of the function, particularly the significance of the leading dimensions (lda, ldb, ldc) and how they relate to matrix storage in memory. The conversation includes practical coding examples and issues encountered while trying to perform matrix multiplication.
  • One participant expresses confusion about the leading dimensions (lda, ldb, ldc) in the cblas_dgemm function and how they affect matrix operations.
  • Another participant provides an explanation of how matrices are stored in memory, highlighting the difference between row-major and column-major storage, and how strides relate to these storage formats.
  • A participant realizes their initial misunderstanding was related to pointers in C rather than the stride parameters, leading to a successful adjustment in their code.
  • There is a mention that BLAS is written in Fortran, which may influence how matrices should be passed from C, considering the different storage orders.
Participants generally agree on the importance of understanding memory storage formats and how they affect the use of cblas_dgemm. However, there is some uncertainty regarding the implications of leading dimensions and how they should be applied in specific coding scenarios.
Some limitations in the discussion include the potential for misunderstandings related to pointers in C and the specific requirements for matrix dimensions when using cblas_dgemm. The conversation does not resolve all uncertainties regarding the best practices for using the function.
KStolen
Hi guys, I'm having trouble understanding how this routine works.
cblas_dgemm is a BLAS function that gives C <= alpha*AB + beta*C
where A,B,C are matrices and alpha, beta are scalars.
Code:
 void cblas_xgemm (
     const enum CBLAS_ORDER Order,
     const enum CBLAS_TRANSPOSE TransA,
     const enum CBLAS_TRANSPOSE TransB,
     const int M,
     const int N,
     const int K,
     const SCALAR alpha,
     const TYPE * A,
     const int lda,
     const TYPE * B,
     const int ldb,
     const SCALAR beta,
     TYPE * C,
     const int ldc)
It takes 14 parameters, listed http://www.psatellite.com/matrixlib/api/lapack.html" .
http://en.wikipedia.org/wiki/General_Matrix_Multiply" on wikipedia.
I don't understand what the "major stride" (lda,ldb,ldc) is or how it works, despite the explanations given on both sites.
Here are my example matrices:
[itex]A = \begin{bmatrix}1 <br /> &1 &1 &1 \\ 1 <br /> &1 &1 &1 \\ 1<br /> &1 &1 &1 \\ 1<br /> &1 &1 &1 <br /> \end{bmatrix}[/itex]
[itex] B = \begin{bmatrix}1 <br /> &1 &1 &1 \\ 1 <br /> &1 &1 &1 \\ 1<br /> &1 &1 &1 \\ 1<br /> &1 &1 &1 <br /> \end{bmatrix}[/itex]
[itex] C = \begin{bmatrix}0 <br /> &0 &0 &0 \\ 0 <br /> &0 &0 &0 \\ 0<br /> &0 &0 &0 \\ 0<br /> &0 &0 &0 <br /> \end{bmatrix}[/itex]
I want to be able to take the bottom quarter submatrices of A and B, multiply them and add them to C such that
[itex] C = \begin{bmatrix}0 <br /> &0 &0 &0 \\ 0 <br /> &0 &0 &0 \\ 0<br /> &0 &2 &2 \\ 0<br /> &0 &2 &2 <br /> \end{bmatrix}[/itex]
Here's an excerpt from my code:
Code:
//where n is the matrix size, in this case 4
void Multiply(int n, int blockSize, double** a, double** b, double** c)
       cblas_dgemm(CblasRowMajor,CblasNoTrans, CblasNoTrans, n, n , n , 1.0, a[0], n, b[0], n, 1.0, c[0], n);
This code successfully multiplies A by B and gets C, a matrix filled with 4's.
I'm thinking something like:
Code:
       cblas_dgemm(CblasRowMajor,CblasNoTrans, CblasNoTrans, 2, 2 , 2 , 1.0, a[1], n, b[1], n, 1.0, c[1], n);
but that returns
[itex] C = \begin{bmatrix}0 <br /> &0 &0 &0 \\ 2 <br /> &2 &2 &2 \\ 0<br /> &0 &0 &0 \\ 0<br /> &0 &0 &0 <br /> \end{bmatrix}[/itex]
instead.
I think it's because I don't understand the lda, ldb and ldc parameters. Is it possible to get what I want here, through only using cblas_dgemm? Obviously, I could iterate over the arrays with loops but I'd prefer not to have to do that.
Well I realized what I was doing wrong, so I thought I'd put the description here for anyone who needs to know.
lda, ldb and ldc (the strides) are not relevant to my problem after all, but here's an explanation of them :
The elements of a matrix (i.e a 2D array) are stored contiguously in memory. However, they may be stored in either column-major or row-major fashion. The stride represents the distance in memory between elements in adjacent rows (if row-major) or in adjacent columns (if column-major). This means that the stride is usually equal to the number of rows/columns in the matrix.
Matrix A =
[1 2 3]
[4 5 6]
Row-major stores values as {1,2,3,4,5,6}
Stride here is 3
Col-major stores values as {1, 4, 2, 5, 3, 6}
Stride here is 2
Matrix B =
[1 2 3]
[4 5 6]
[7 8 9]
Col-major storage is {1, 4, 7, 2, 5, 8, 3, 6, 9}
Stride here is 3
However, my issue was very simple in the end. I just didn't understand pointers. When you reference an array in C, what you are really referencing is the memory location of the first element of that array. Hence, to perform the operation I required, simply do this:
Code:
//if blocking, replace M,N,K with blockSize
       cblas_dgemm(CblasRowMajor,CblasNoTrans, CblasNoTrans, 2, 2 , 2 , 1.0, a[2]+2, n, b[2]+2, n, 1.0, c[2]+2, n);
I'm reasonably sure that the elements of a two-dimension array are stored in row-major order in C and other C-based languages. If I remember correctly, Fortran does things differently, storing elements of a matrix in column-major order.
That's right Mark. Because BLAS is written in Fortran, matrix row/column order is something you should be aware of when passing it matrices from C.
  • · Replies 23 ·
9K
