How Does Changing Zero Adjust Resistance Affect an Ohmmeter's Accuracy?
  • Thread starter Thread starter Mustafa111
    Resistance Zero
Mustafa111
Member warned about using template for posts in the Homework Sections of PF.
hello there i kinda need help with this, image attached in the thread
this is the ohmmmeter circuit and i have two questions :
-what is the effect of R2 when it become lower than Rm?
-what is the effect of R2 when it become higher than Rm?
Rm=internal resistance of ohm-meter
R2=zero adjust resistance
edit:i study computer engineering techniques and this is the instrument and measurements
so hopefully this is the right place to post
  • Circuit schematic of a series ohmmeter: meter Rm with zero-adjust resistor R2 and shunt current I2 across battery E, in series with R1, terminals A and B, and unknown resistor Rx.
In your figure the bottom end of R2 is connected to the node where E and Rm connect, but the "wire" looks more sketchy than the other wires of the drawing. Is that connection intentional?
You need to make an attempt at a solution before we can offer any detailed help. Here's a hint though: You've identified R2 as a zero adjust resistance. What's the standard procedure for zero-adjusting an ohmmeter? Think about comparing the magnitudes of the currents passing through the meter Rm and R2.
