How Does Covariant Differentiation Affect Tensor Fields?
  • Thread starter Thread starter CAF123
    Fields Tensor
2 replies · 2K views
CAF123
Let ##T## be a ##(1, 1)## tensor field, ##\lambda## a covector field and ##X, Y## vector fields. We may define ##\nabla_X T## by requiring the ‘inner’ Leibniz rule, $$\nabla_X[T(\lambda, Y )] = (\nabla_XT)(\lambda, Y ) + T(\nabla_X \lambda, Y ) + T(\lambda, \nabla_X Y ) . $$
(a) Prove that ##\nabla_XT## defines a ##(1, 1)## tensor field.
(b) Prove that the components of the ##(1, 2)## tensor ##\nabla T## are, $$\nabla_cT^{a}_{\,\,\,b} = e_c(T^{a}_{b}) + \Gamma^{a}_{\,\,dc}T^{d}_{b} − \Gamma^{d}_{ bc}T^{a}_{d}$$
(c) Deduce that the Kronecker delta tensor is covariantly constant ##\nabla \delta = 0.##
[/B]
Tensor fields and linearity
[/B]
Really just need to check what I am going to do is correct. For a), ##\nabla_X T## defines a (1,1) tensor if it is linear in the arguments ##X## and ##Y##? Linear in ##X## by definition of a connection and for ##Y##;
$$\nabla_X (T (\lambda, fY)) = (\nabla_X T)(\lambda fY) + T(\nabla_X \lambda, fY) + T(\lambda, \nabla_X (fY)) $$ which can be written using the axioms of a connection $$ f(\nabla_X T)(\lambda, Y) + fT(\nabla_X \lambda, Y) + fT(\lambda, f \nabla_X Y) + T(\lambda, X(f)Y)$$ It doesn't seem to be linear in Y at all?
Thanks!
[/B]
[/B]
Thanks!
Well, you started with the equation:
[itex]\nabla_X (T(\lambda, Y)) = (\nabla_X T)(\lambda, Y) + T(\nabla_X \lambda, Y) + T(\lambda, \nabla_X Y)[/itex]
You can rewrite this to get:
[itex](\nabla_X T)(\lambda, Y) = \nabla_X (T(\lambda, Y)) - T(\nabla_X \lambda, Y) - T(\lambda, \nabla_X Y)[/itex]
So it's the combination of all three terms on the right-hand side that must be linear in [itex]\lambda[/itex] and [itex]Y[/itex]. The individual terms don't have to be linear. To prove it's linear in [itex]Y[/itex], replace [itex]Y[/itex] by [itex]f Y[/itex]:
[itex](\nabla_X T)(\lambda, f Y) = \nabla_X (T(\lambda, f Y)) - T(\nabla_X \lambda, f Y) - T(\lambda, \nabla_X (f Y))[/itex]
Then you have to prove that the right-hand side is equal to [itex]f (\nabla_X (T(\lambda, Y)) - T(\nabla_X \lambda, Y) - T(\lambda, \nabla_X Y))[/itex]
To prove this, you have to use the linearity of [itex]T[/itex] and the Leibniz rule to rewrite the right-hand side so that hopefully you can get [itex]f[/itex] on the outside. What that means is that derivatives of [itex]f[/itex] have to cancel.
Thanks! Ok so I proved the linearity in ##Y##, can I use the same method to find the linearity in ##\lambda##? So let ##\lambda \rightarrow f \lambda##?
For part b), I am not sure how much detail is required for an answer. The definition I have in my notes is that 'Given an ##(r,s)## tensor field ##T##, the covariant derivative ##\nabla T## is an ##(r,s+1)## tensor with components $$\nabla_c T^{a_1 ... a_r}_{\,\,\,\,\,\,b_1 ...b_s} = e_c T^{a_1...a_r}_{\,\,\,\,b_1...b_s} + \Gamma^{a_1}_{dc} T^{d...a_r}_{\,\,\,\,b_1...b_s} + ... + \Gamma^{a_r}_{dc}T^{a_1 ...d}_{\,\,\,\,b_1 ... b_s} - \Gamma^d_{b_1 c} T^{a_1...a_r}_{\,\,\,\,d...b_s} - ... - \Gamma^{d}_{b_s c} T^{a_1...a_r}_{\,\,\,\,\,b_1...d}$$ So applying this gives the result immediately, as far as I can see we are evaluating all the possible contractions of the covariant and contravariant components of the tensor. Do you think this is fine? And is this result a definition or does it follow from something? Thanks!
