How does frequency multiplexing work ?
  • Thread starter Thread starter RipClaw
    Frequency Work
Frequency multiplexing allows multiple signals to be transmitted over a single cable by modulating them onto different carrier frequencies. The demultiplexing process involves tuning a receiver to a specific frequency, where it uses a local oscillator to mix with the incoming signal, effectively isolating the desired channel. This mixing spreads the energy of unwanted signals outside the passband of a bandpass filter, which then suppresses them, allowing only the target channel to be processed. Each channel's information is carried on a specific frequency, and the receiver's filters ensure that only the intended signal is extracted from the combined input. Understanding these principles is essential for grasping how cable networks deliver multiple TV channels simultaneously.
RipClaw
I don't understand how frequency multiplexing works on one cable (For example :a cable tv network that sends 100s of TV channels to a TV)I understand that we can mix frequencies, and then demultiplex them.
But how does demultiplexing happen ?
After mixing, we get a soup.(which contains the crusts & troughs of various channels added/subtracted)
Let us assume that the crest formed by 2 inputs signals adds to give 5 volt.
Now how does the receiver/filter know the original signals were 1V and 4V , 3V and 2V, or other various combinations ?
They aren't really multiplexed. In a hypothetical scenario we send out one carrier wave over the air on one antenna and then send a different one on a different frequency out on a different antenna but the receiver will get both signals. In the receiver they are selected out the same way they would be in your cable scenario. Do some research on receivers and filters. As far as combining several TV channels into the same cable goes, typically they use combiners and filters to do this. Each modulator has a filter on the output that allows it to only 'see' within it's own frequency passband. All of the outputs are then connected to the cable. This process generally is not considered multiplexing. At least I have never heard it termed that way.
You really need an RF guy hear. I'm not one.
Say your channel information is riding on a 4.5 MHz carrier. If you mix a 4.5 MHz signal with the signal you will demodulate into base band. But if the demodulator frequency you mix into the signal is variable (slighly lower or higher than 4.5 MHz) you can adjust the channel centerband to be centered on the bandpass filter. I think this usual method used today to select channels where variable capacitance diodes are used to tune the demodulator frequency.
Edit: you can be sure I'm not an RF guy. What I've called a demodulator frequency is misnamed. It's something like intermodulation frequency.
First, freq multiplexing is actually time-addition of signals that are frequency separated, having been modulated with different carrier frequencies.
Basically it involves multiplying in time carrier and the signal. Then the output of such modulated channels is time added in the cable.
Without getting into math, this is the simple way of looking at what happens in a receiver.
When you tune the receiver, you select a "channel", that is, you set the center frequency of the local oscillator and you look at a freq window (= bandwidth of the signal). The local oscillator freq is multiplied to the incoming signal (demodulation) and the output is passed thru a band pass filter that has the center freq = selected channel center freq and the bandwidth = the signal bandwidth (which is fixed for all channels. For NTSC TV I think it is 6 MHz). The act of multiplying the incoming "composite" signal with a local oscillator signal gives the HIGH gain for ONLY that component of the incoming signal that was originally modulated by the same carrier freq (center freq) on the sender's side, and it spreads out the other contributors in such a way that they lie out of the passband of the band pass filter. That is if you wanted to see CNN channel, and out of 5 V crest its only 3 V of CNN and rest are contributions of other channels, the demodulation causes the energy of other channels to spread out of the passband and band pass filter suppresses them. You are left with the energy (and some noise) of CNN only.
Note that w.r.t. to any given TV channel of interest, the signal contributions from all other channels can simply be considered noise.
I don't want to write equations for you, but take any basic textbook on telecommunications and it will suffice.
Hope that helps.
sai
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
13K
