How Does Friction Affect the Ball's Velocity at the Table Edge?
  • Thread starter Thread starter cheerspens
    Force Velocity
The discussion revolves around a physics problem involving a ball moving towards the edge of a table, considering the effects of friction on its velocity and the time it takes to hit the ground after falling. The problem includes parameters such as the ball's initial velocity, mass, frictional force, and the height of the table.
  • Mixed
  • Participants explore various equations of motion to determine the ball's velocity at the table's edge and the time to hit the ground. There are attempts to calculate acceleration due to friction and to decompose the motion into horizontal and vertical components. Questions arise regarding the setup of variables and the interpretation of vertical velocity.
Some participants have provided calculations and corrections, while others question the validity of certain values and approaches. There is ongoing exploration of the relationship between horizontal and vertical motion, with no explicit consensus reached on the final answers.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. Assumptions about initial conditions and the effects of gravity are also being discussed.
cheerspens
The ball is moving at 2.0m/s just 40cm before it hits the table edge. If the ball has a mass of 51.3 grams and experiences a 0.23 N frictional force between it and the table, how fast will it be moving when it reaches the table's edge?
The table is 0.92m tall. How long will it take the ball to hit the ground?
X=Xo+Vot+(0.5)at2
Y=Yo+Voyt+(0.5)at2
X=Xo+Voxt
FNET=ma
Fg=mg
Quadratic Formula
I used FNET=ma to solve for the acceleration and got -4.48m/s2. Then I used X=Xo+Vot+(0.5)at2 and the quadratic formula to solve for t and got 0.3 sec. I then plugged this into V=Vo+at to get a velocity of 0.656m/s. Is this correct?
For the second question: How long will it take for the ball to hit the ground?
I seemed to be stumped. Maybe my velocity I solved for is incorrect or I'm not even setting it up right?
Thanks in advance for any help.
Your result for the horizontal velocity on the table is correct.
When the ball is falling from the table, its motion can be decomposed into a horizontal motion with constant velocity (what you just calculated) and a vertical motion (free fall) with constant acceleration g. The time of reaching the ground is independent of the horizontal velocity.
ehild
So the answer I'm getting is that it will take 0.09 sec for the ball to hit the ground and it will land 0.1719 meters away from the table.
Does this seem correct?
No. How did you get 0.09 s?
ehild
So if I were to set up a variable list for how long it will take the ball to hit the ground would it look like the following?
Xo=0m
X=?
Vox=1.91m/s
t=?
Yo=0.92m
Y=0m
Voy=-9.8m/s
g=-9.8m/s2
Using these values I got 0.09 seconds.
I do not see how did you get Voy=-9.8m/s:
ehild
o I have redone this problem making some corrections and have come up with these answers:
-When the ball reaches the table's edge it will be moving 0.65m/s.
-It will take the ball 0.44 seconds to hit the ground.
-The ball will land 0.286 meters away from the table?
Have I gotten this problem correct?
And if I were to graph my y-component velocity, would it be a constant 0m/s?
Thanks!
Your calculation is correct now.
vy is the vertical velocity. Do you really mean that it is constant and equal to zero?
ehild
Because Voy is 0m/s I'm not sure how to graph the vy component. Once the ball hits the ground doesn't that also mean the velocity is 0m/s there?
No, falling objects do hit the ground with some velocity. Their velocity becomes zero after they touch the ground, because of the interaction with it.
Zero velocity means no motion. Do you really think that a ball which falls of the table , will not move downward? How does it get to the ground?
ehild
How do you solve for a vertical Vf?
Would it be like solving the equation V=[tex]\Delta[/tex]X/[tex]\Delta[/tex]t?
It is average velocity, but let's start with it. What is the average vertical velocity of the ball?
2.091m/s
cheerspens said:
2.091m/s
You see, the vertical (y) velocity component can not be constant as it is zero at the beginning of the fall and about 2.1 in m/s in average. It increases with time, the ball accelerates. What is the magnitude of this acceleration?
ehild
f=ma
0.23N=0.0513a
a=4.48m/s^2
v^2=u^2+2as
v^2=(2)^2+2(4.48)(40)
v^2=360
v=19m/s
s=ut+1/2at^2
0.92=(19)t+1/2(9.8)t^2
4.9t^2+19t-0.92=0
t=0.05s
Correct me if I'm wrong
Thanks
What force acts on the ball after it left the table and moves in air?
