How does induced charge separation work and why can it be confusing?
1 reply · 28K views · last reply
whoareyou
I am having trouble understanding the concept of induced charge separation. In my textbook, there is a diagram that demonstrates the procedure, but it gets confusing because the first image is normal, and then it gets inverted? I don't understand in the second set-up if it is being grounded or not.
Two-panel diagram of induced charge separation: left, a pith ball with net + on one side and net - on the other as electrons are repelled by a negative ebonite rod; right, a metal-leaf electroscope with a positive charged top and leaves, showing net + above and net - below as electrons are repelled by the rod.
The first image is for a hanging ball. The second is for an electroscope with a ball attached to two leaves, which are repelling. They are both confusing because they show + and - charges mixed together - which is reality, but still confusing. I have simplified it to make it clearer:
Two diagrams of charge induction: left, a charged rod brings a pith ball's positive charges toward it, leaving net positive and net negative sides; right, a metal-leaf electroscope with a ball, showing net positive at top and net negative charges on the leaves.
On the left, the negative rod has pulled some positive charges on the ball closer and pushed some negative ones away to the other side. induced charge separation, pushing some negative charges (electrons) away and leaving some atoms with a net positive charge nearby.
On the right, the negative rod has pulled positive charges up into the ball, and negative ones down pushed some negative charges (electrons) down onto the leaves (which then repel each other). Of course there are many charges of both kinds all over the place and not shown for clarity.
[edit: Text modified by moderator (blue text) to reflect the fact that in most common materials, especially solids, atomic nuclei are the source of the positive charges and are fixed in place for all practical purposes and only the electrons have the luxury of mobility. The electrons can leave behind atoms with a net positive charge. The story is different for other forms of matter where the atoms themselves are mobile, such as liquids, gases, and plasmas]
