How Does Initial Displacement Affect Different Damped Harmonic Oscillators?
8 replies · 3K views
Fjolvar
A damped harmonic oscillator is displaced a distance xo from equilibrium and released with zero initial velocity. Find the motion in the underdamped, critically damped, and overdamped case.
d2x/dt2 + 2K dx/dt + ω2x = 0
Underdamped: x = C*e-Ktcos(ωt-[itex]\gamma[/itex])
Overdamped: x = A*e-K-t+B*e-K+t
Critically Damped: a*e-Kt*(1+bKt)
I haven't attempted the solution because I'm not sure how to incorporate xo into the equations. I understand that at time t=0, x=xo, but how do I use this fact? Any help would be greatly appreciated. Thank you in advance.
Each of the solutions has two arbitrary constants. You need to determine those using the initial conditions. In the critically damped case, for example, when t=0, you have x(0)=a; therefore, you know that a=x0. By using the fact that the oscillator starts at rest, you can similarly solve for b.
Hmm, is the equation I have for under damped correct then, since there is only one constant?
I solved the equations of motion for the Under-Damped and Critical-Damped conditions, but I'm having trouble finding the Over-Damped constants.. Any advice?
If I write the equation for over-damping using the initial conditions for t=0, I get: Xo=Ae^(-K) + Be^(-K)... which just gives me e^(-K)*(A+B). I'm not sure how to solve for A and B given this.. Any help before class would be greatly appreciated.. again thanks in advance.
Your solution for the overdamped case is incorrect.
I believe that is just the solution for the real part? I'll have to look for the general solution..
Your "underdamped" solution does have two constants, C and [itex]\gamma[/itex]
Your "overdamped" solution, [itex]x= Ae^{-K-t}+Be^{-K+t}[/itex] should be [itex]x= Ae^{Kt}+ Be^{-Kt}[/itex].
HallsofIvy has uncharacteristically made a mistake regarding the overdamped solution. In the overdamped case, the characteristic equation, [itex]r^2+2Kr+\omega^2=0[/itex], has two real roots
\begin{align*}
r_+ &= {-K}+\sqrt{K^2-\omega^2} \\
r_- &= {-K}-\sqrt{K^2-\omega^2}
\end{align*}so the solution is
\begin{align*}
x(t) &= Ae^{r_+ t}+Be^{r_- t} \\
&= Ae^{(-K+\sqrt{K^2-\omega^2})t}+Be^{(-K-\sqrt{K^2-\omega^2})t}
\end{align*}So when t=0, you get x(0) = A+B.
