How Does Jet Stream Speed Affect Airplane Ground Speed?
1 reply · 5K views
mmg0789
Long flights at midlatitudes in the Northern Hemisphere encounter the jet stream, an eastward airflow that can affect a plane's speed relative to Earth's surface. If a pilot maintains a certain speed relative to the air (the plane's airspeed), the speed relative to the surface (the plane's ground speed) is more when the flight is in the direction of the jet stream and less when the flight is opposite the jet stream. Suppose a round-trip flight is scheduled between two cities separated by 3600 km, with the outgoing flight in the direction of the jet stream and the return flight opposite it. The airline computer advises an airspeed of 810 km/h, for which the difference in flight times for the outgoing and return flights is 63 min. What jet-stream speed (in km/h) is the computer using?
im thinking (x-x0) = 1/2(v0 + v)t
maybe
attached is a picture of what i think this scenario looks like,
i found Vpg for the plane going to be cos(theta)/810
but I am not really sure what else to do
I think the problem intends you to take the jet stream to be traveling in the same direction as the plane. So there is no theta to worry about. Just write an expression for the one way travel time in each direction, write an expression that says their difference is 63min and solve it for the velocity of the jet stream.
