How Does Kirchhoff's Law Apply to Calculating Currents and Voltage Differences?
  • Thread starter Thread starter flyingpig
    Law
42 replies · 5K views
flyingpig
I so got this, but I just need your word to boost my ego
http://img263.imageshack.us/img263/7302/problemq.th.png
Uploaded with ImageShack.us
Find the current in each resistor and the potential difference between a and b
Before I even go find the current in each resistor, I need to find the branch, and let's just start and end there
http://img819.imageshack.us/img819/4913/partsol.th.png
So as you can see the direction and the labelled Ia and Ib in the circuit.
Then I get
(1) [tex]12 - 2I_a - 4I_a + \frac{4}{3}I_b = 0[/tex]
(2) [tex]8 - 6I_b - \frac{4}{3}I_b + \frac{4}{3}I_a = 0[/tex]Let me explain, for equation one, I did the loop counterclockwise and the (4/3) accounts for the resistor equivalent in that circuit FOR the bigger loop
The second equation follows the same argument. My concern is that for the top smaller loop (Ia), should I have used [tex]12 - 2I_a - 4I_a + 4I_b - 2I_b= 0[/tex] instead? I am pretty sure I got equation 2 two.
You don't need to do anything with the resistances but use them as they're given. The 4/3 values you've written should just be 2.00's.
Which loop are you talking about?
You've indicated two loops; one with current Ia and one with current Ib. The equations for neither of them require a "4/3" resistance value. They should be 2.00's.
Hi flyingpig:smile:
(Hope this thread is not just for Sammy, that will be awkward :-p)
It doesn't matter if you calculate the net resistance and then apply KIRCHHOFF laws or apply them directly. even if you split the 4Ω resistance into 4 1Ω resistance in series, yo'll get the same result.
But you can't calculate net resistance if two resistances just because they are in series in the loop you have chosen. That will give wrong answer.
ONLY FIND NET RESISTANCE IN SERIES OR PARALLEL IF THEY ARE IN SERIES OR PARALLEL IN ORIGINAL CIRCUIT AND NOT IN THE LOOP CHOSEN
But how did gneil get just 2.00Ω?
flyingpig said:
Why just 2.00s?
Because it's a 2.00 Ohm resistor in the loops. The fact that it happens to "belong" to two loops doesn't matter; it is still just a 2.00 Ohm resister as far as the loop equations are concerned. The fact that it appears in both equations takes care (mathematically) of the relationship between the loop currents that pass through it.
But the 4.00Ω also belongs to both loops, so why only include 2.00Ω?
If you are talking about the loop with both batteries then yes they both do share the 4Ω resistance.
But why are you so concerned about the resistances shared?
Just do it the old way, write eqn for both loops and solve simply, and here you can't calculate net resistance, that would be wrong
(1) [tex]12 - 2I_a - 4I_a +4I_b + 2I_b= 0[/tex]
(2) [tex]8 - 6I_b + 4I_a + 2I_a = 0[/tex]
Really? The currents that you drew did not both pass through the 4 Ohm resistor. Perhaps you'd better explain precisely how you've chosen your loops.
I see two very obvious loops, namely the one beginning with the 8V supply and passing through the 6.00 Ohm resistor, then the 2.00 Ohm resistor, and returning to the 8V supply, and the other commencing with the 12.0V supply and passing through the 2.00 Ohm resistor and then the 4.00 Ohm resistor and back to the 12V supply. And it appeared that you drew the currents accordingly...
I really can't understand what loops you have taken :confused: ... can you show them?
Wrong loop, if we were to just take the 2Ω resistor then
(1) [tex]12 - 2I_a - 4I_a + 2I_b= 0[/tex]
(2) [tex]8 - 6I_b + 2I_a = 0[/tex]
You missed another 2Ib in the second equation. It's a loop! Ib must flow through each component in the loop, even those components that Ia also flows through!
(2) [tex]8 - 6I_b + 2I_a - 2I_b= 0[/tex]
I still find it unintuitive that we only need the 2 ohm resistor
Why? The loops are separate. The loop currents are confined to their loops. They may pass through shared components, but they are separate currents nonetheless.
That's an answer I can accept, but it isn't enough to convince me
I can only imagine that you must be fuzzy on the concept of what constitutes a loop and how KVL works around a closed path.
OK.
(I've never been inserted into a title before!)
I'll read over the posts & get back to you soon, I hope.
Here's you circuit redrawn in a straightforward manner (without the stylistic "jogs" in the wiring), with two possible choices of loops shown. Both choices are fine, and will lead to the same answers if you write the loop equations properly. The only real restrictions on the set of loops you choose is that they don't cross themselves and they must as a set pass through every component in the circuit.
This means that when you "walk" around a loop (one of the closed paths indicated), you include every component that the loop as drawn passes through, and NEVER include components that it does not pass through -- that's the job for other loops that do include those components. It's okay for loops to share components.
When writing a term for a given component in a loop equation, you must include every loop current that passes through it. This is what "links" the simultaneous equations together.
For the two currents you are using and the loops that naturally follow from them these are the correct equations.
I see that gneill and his considerable patience have gotten you to the right result.
The 2Ω resistor is the only component common to both loops and which has both currents passing through it. You could rewrite your two equations as:
(1) [tex]12 - 2(I_a-I_b) - 4I_a = 0[/tex]  As you go around the upper little loop counter-clockwise, the current through the 2Ω resistor is Ia - Ib.
(2) [tex]8 - 6I_b - 2(I_b-I_a)= 0[/tex]  As you go around the lower little loop counter-clockwise, the current through the 2Ω resistor is Ib - Ia.
My guess is that initially, you were mixing two methods of circuit analysis: Kirchhoff's & the superposition method.
Here's how i drew the circuit with currents ...
And maybe you should look at some example of using Kirchhoff laws
Edit:
Here they are:
Edit:
Here they are:
What do you guys use to draw your diagrams...? I've seen that guy's videos, they are a replacement for my professor basically
If only all of them look like that
But it is kinda tempting to think it does...
i used paint (win 7)
I use Visio, then paste the result into Paint and save it in the desired format (jpg, png, etc.). I wasn't happy with the way Visio saved "non native" formats.
I use Open Office Draw, then export as jpeg, or png or ..., then use gimp to re-size and/or trim the border if needed.
(Usually I simply avoid drawing if possible! LOL.)
