How Does Momentum Change When a Ball Bounces Off a Wall?
The discussion revolves around the change in momentum of a ball that bounces off a wall, specifically when it is rolled into the wall and returns at the same speed. Participants are exploring the implications of momentum as a vector quantity and the significance of direction in this context.
  • Participants are attempting to determine the change in momentum using the initial and final velocities. Questions are raised about the signs of the momentum values and how they relate to the direction of the ball's motion.
There is an ongoing exploration of the relationship between initial and final momentum, with some participants suggesting that the change in momentum is 2mv. Others are questioning the assumptions about the direction of velocity and how it affects the calculation.
Participants note that the original velocity could be considered negative, leading to different interpretations of the momentum values. The discussion reflects a lack of consensus on the directionality of the momentum but acknowledges that the magnitudes remain the same regardless of the chosen positive direction.
yamugushi
1. Homework Statement
A ball is rolled into a wall and bounces back at the same speed, the change in momentum is?
2. Homework Equations
Ein = Eout
3. The Attempt at a Solution
I thought it was m(v) but I got it wrong (doing test corrections ATM)
Note I'm having trouble editing, so I made a new thread, I am not trying to spam.
If the velocity before impact is v, what is the velocity after impact?
(remember, velocity is a vector quantity, so direction is important)
So it's be -mv... but there aren't any negative answers:
I have
.5
and what I answered MV (all above are times MV as well)
So momentum before is mv, and momentum after is -mv, so that change in momentum is ?
2mv?
yamugushi said:
2mv?
is that one of the answers?
yes, the answers were:
0mv
1mv
1.5mv
.5mv
2mv
Just to note:
The original velocity must have been negative. The initial momentum was [tex]P_1=-mv[/tex].
Following the bounce, the final momentum is [tex]P_2=mv[/tex].
Hence the positive answer: P2-P1=2mv
Either way the magnitudes are the same.
Winzer said:
Just to note:
Yes the magnitudes are the same, but it didn't have to be negative. It depends on the direction you choose as positive.
  • · Replies 19 ·
  • · Replies 21 ·
