How Does Orbital Eccentricity Affect Satellite Calculations?
The discussion revolves around the effects of orbital eccentricity on satellite calculations, specifically focusing on energy and angular momentum in elliptical orbits. Participants are examining the relationship between various orbital parameters and the mathematical formulations that govern them.
  • Participants discuss the conservation of mechanical energy and angular momentum, questioning how to apply these principles to find eccentricity. There are inquiries about specific formulas and the definitions of variables used in the calculations.
The conversation is ongoing, with some participants providing guidance on the use of specific energy and angular momentum. Others express confusion about applying these concepts and seek further clarification on the relevant equations.
There is mention of an attachment that contains important information, but its contents are not detailed in the discussion. Participants also note the potential for misunderstanding due to the ambiguity of terms like "A" and "P" in the original post.
superaznnerd
elliptical orbit question please help
see attachment
2a (average distance of satellite from central body) = A (aphelium) + P (perihelium)
ME = KE + PE
ME = -GMm/24
KE = .5mv^2
PE = -GMm/r
ME orignall = ME final
I tried to put ME = KE + PE = constant.
I solved for theoretical A, and P, if the velocity was only transverse.
Then, I subtracted the theoretical P by the distance caused by the KE. I sitll did not get the answer htough
Please list all of the formulas and steps you did. Not sure what you are defining as A and P.
anyone?
Given the components of the velocity, can you determine the angle at that point? What is the polar equation for an ellipse in terms of the eccentricity?
There is a formula for eccentricity in terms of energy and angular momentum. If you don't know it, then you will have to solve for it using the conservation of energy and the conservation of angular momentum.
I looked at the wiki page, and have no clue hwo to apply conservation of angular momentum. could someone please show me how to do it?
Calculate the angular momentum of the satellite using
[tex]\vec{L} = m\vec{r}\times \vec{v}[/tex]
Don't even bother with the satellite mass. It's just going to divide out in the end. Just use specific energy and specific angular momentum.
Which wiki page? There are several of them.
No, we can't show you how to do it. That would be cheating.
Can you look up the polar form of the equation for an ellipse, in terms of r, $\theta$, and the eccentricity? Can you find the angle, given the components of the velocity?
The polar form of an ellipse has two unknowns: 'a' and eccentricity. So it won't be enough to solve for the eccentricity alone.
I think the original poster has moved on by now.
The sad thing is that the word "eccentricity" is in big bold letters in the attachment in the original post. The OP claims to have "read the wiki page". Which one, I don't know. The wiki page on "Eccentricity" is a redirection page, and one of the redirects is to "Orbital eccentricity". The first equation specifies how to solve this exact problem in general; the third equation specializes this first equation to gravitation. In other words, exactly what the OP needed to use to solve this problem is right there, right up front, on "the wiki page".
10K
