How Does pH Affect Amylase Activity?
  • Thread starter Thread starter GaMeR4LyF
    Ph
4 replies · 12K views
GaMeR4LyF
Hi guys, i have been set some coursework by school on the investigation of the effect of pH on the enzyme amylase. I am abit lost right now only just started A levels. Can someone suggest how i would carry out this investigation? Equipment and method would be much appreciated! And the results need to be quantitative and not qualitative.
well you could use your spit (contains the enzyme) , pieces of bread (substrate) ,lemon juice/vinegar (to provide acidic medium) ,water (ph7.7 preferably distilled water),and an alkaline solution.To test to see if glucose has been produced use an iodine solution.
Blue-black colour indicates that the result is positive.equipment needed : petri dishs :smile:
hmmm...problem with iodine is that it doesn't give accurate enough readings to differenciate between the samples
Try using a stronger acid and a stronger base. Remember salivary amylase works best in a range of +/- 6.0 - 8.0 .:smile:
