How Does Pulling Arms In Affect Angular Velocity on a Rotating Stool?
7 replies · 2K views · last reply
sauri
A skinny student (40 kg) sits on a stool that can rotate, holding two 8 kg bowling balls with his arms out stretched. The stool weighs 20 kg. The student and stool are spun such that they have an angular velocity of 2 rad.s-1.
When the student pulls his arms in towards him, what happens to his angular velocity and what is his final angular velocity when they rest in his lap?
I know I have to find [tex]\omega[\tex] and I think using [tex]L=I\omega[\tex] should be the key. Only L and I are unknown..any ideas?[/tex][/tex]
[tex][tex] <br /> Well, there are no net external torques on the system so it sounds like angular momentum should be conserved.<br /> <br /> -Dan[/tex][/tex]
So L(initial)=L(final), so we find the kinertic energy (Iw^2)/2, find I and and substitute it to L=Iw and find w?
That's about it. Just a quick note on latex, at the end you need to use [/tex] not [\tex], apart from that, your code is correct. If you want to put code on the same line use the [itex]tags instead of [tex]<img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" />[/tex][/itex]
When trying to find I from the k.e equation there was a prob that I ran into. The kinetic energy of the system is not given. K.E=(Iw^2). I don't see how (mv^2)/2 can be used as we do not know v, only w is known.
It looks like you have to make some assumptions about the persons dimensions and the length of his arms.
Rotational kinetic energy is [tex]\frac{1}{2}I \omega^2[/tex]
Moment of Inertia (I) is [tex]I = mr^2[/tex]
Linear velocity (v) is [tex]v = r \omega[/tex]
where r=2(pi) right?. Then we find v and sbstitute to (mv^2)/2=(Iw^2)/2 and find I which we sunstitute into L=Iw and find L right?. so what's [tex]I = mr^2[/tex] for?
r is the radius.
[tex]KE = \frac{1}{2}m v^2[/tex]
[tex]= \frac{1}{2}m (r \omega)^2[/tex]
[tex]= \frac{1}{2}m r^2 \omega^2[/tex]
[tex]= \frac{1}{2}I \omega^2[/tex]
The [tex]I = m r^2[/tex] only applies for a point-mass or ring (since all the units of mass have the same I). The moment of inertia for anything else is a sum of the moments of inertia for all of the point-masses that make up the object.
For the original problem, you need to model the person-chair as a cylinder and find the moment of inertia for a cylinder and model the weights as point masses. You can derive the equation for the moment of inertia for a cylinder yourself ([tex]I = \Sigma m_i r_i^2[/tex]) or look up the formula in a book or on-line.
