- 50,420
- 26,460
Maxila said:It is the change of position of the crystal oscillator
But the crystal as a whole does not move. What is moving?
PeterDonis said:But the crystal as a whole does not move. What is moving?
OK, but this means you can't question my answer.Maxila said:I’m sure you already know x for the photon and that x is defined as wavelength = c/frequency. I’m also sure you don’t need me to divide out the values for you.
I have no idea what you are talking about. You are making claims that are confusing to me.Maxila said:The math of time to a ratio of x/s is also too simple and absolute to worry about what distance the oscillator travels when we can conclude for certain that the oscillator speed is s < c and that for x it must be proportional to the value of s.
I don't believe there is any crystal that is oscillating at 9,192,631,770 Hz.Maxila said:If it is sincerely that important to you, I’m sure one could write the NIST time unit and get a speed for the crystal oscillator’s frequency and that would give us an x value per t.
bahamagreen said:Does that not qualify as movement?
ghwellsjr said:You gave the value of frequency in post #8 as 9,192,631,770 Hz. Since c is 299,792,458 m/s, the wavelength is 0.0326 m or 3.26 cm which is over an inch. You have stated that there is an oscillation that covers a distance of over an inch. As PeterDonis asked, what is oscillating back on forth over a distance of 3.26 cm?...
Did it ever occur to you that if there is a back and forth motion of something over a distance of 3.26 cm then the total distance will be 6.52 cm and at 9,192,631,770 Hz, that something will be traveling at twice the speed of light. Are you sure you want to continue with this claim?
Maxila said:"A detector at the end of the tube gives an output according to the number of cesium atoms striking it and peaks when the frequency is absolutely correct. This peak is then used to make slight corrections to the crystal oscillator that controls the clocking mechanism, locking in the frequency. This locked frequency is then divided by 9,192,631,770 which results in the familiar one pulse per second."
Maxila said:ghwellsjr said:You gave the value of frequency in post #8 as 9,192,631,770 Hz. Since c is 299,792,458 m/s, the wavelength is 0.0326 m or 3.26 cm which is over an inch. You have stated that there is an oscillation that covers a distance of over an inch. As PeterDonis asked, what is oscillating back on forth over a distance of 3.26 cm?...
http://www3.nd.edu/~techrev/Archive/Winter2002/a4.html
These clocks do not keep time according to atomic decay, but rather by the oscillation of the nucleus of an atom and its surrounding electrons. The mass of the nucleus and the gravity and electrostatic “spring” between the positively charged nucleus and the electrons set the oscillation frequencies.
Maxila said:As for the other part I KNOW you are smart enough that if you cared too, you could look at the references I've linked and re-read what was said carefully; by applying an objective scientific methodology you'd uncover the mistaken assumptions in saying:
ghwellsjr said:Did it ever occur to you that if there is a back and forth motion of something over a distance of 3.26 cm then the total distance will be 6.52 cm and at 9,192,631,770 Hz, that something will be traveling at twice the speed of light. Are you sure you want to continue with this claim?
Because I doubt your sincerity, and ability to be objective, I am not going to repeat what I've already shown and said to correct the obvious mistaken assumptions above. (Hint: The frequency of the Earth's rotation is the same at the Equator, Arctic circle, or any other latitude, even though it's rotational speed and the distance traveled are not.)
That is what wikipedia says when you type "motion" into the search window. But when you click on that particular option, the article says nothing about motion being a change in time. I think the above quote is a mistake and probably should say "change in position with respect to time".TrickyDicky said:There is some semantics confusion here and both sides in this discussion are partly right.
Wiki: "Motion (physics), any movement or change in position or time"
The motion of the atoms as a whole has nothing to do with the physics of the hyperfine transition frequency. Each atom is emitting one particular precise frequency, which would not be useful to make an atomic clock. You need a large number of them doing it at the same time and their motion with respect to themselves increases the inaccuracy of the timing.TrickyDicky said:It all comes down to what one understands as motion,classical change of position in time or simply change in time if one concludes from the basics of QM that the HUP prevents the absence of motion microscopically, or from the basics of relativity that there is no such thing as absolute rest.
In this last case a hyperfine transition frequency would imply motion, and in any case this transition is used as the frequency standard, and the atoms obviously move(one would need absolute zero temperature to detain their motion completely) in any of the senses referred above, both elements are needed to be able to measure time in practice.
Within each atom, electrons exist in an area around the nucleus. This area is called the electron cloud. According to Bohr's model of the atom, electrons have a high velocity, and the larger the nucleus they are orbiting the faster they would need to move. If electrons 'move' about the electron cloud in strict paths the same way planets orbit the sun, then electrons would be required to do so at speeds which far exceed the speed of light. However, there is no reason that one must confine one's self to this strict conceptualization, that electrons move in paths the same way macroscopic objects do. Rather one can conceptualize electrons to be 'particles' that capriciously exist within the bounds of the electron cloud.
TrickyDicky said:the atoms obviously move
That is why I explained how a frequency, or change in time can be understood as a change in position wrt time, if you want to question it go ahead.PeterDonis said:Maxila can speak for himself, of course, but I have understood him to consistently mean "change in position with respect to time", which is, as ghwellsjr noted, the standard definition.
I didn't confuse it, just mentioned it just in case you didn't admit(with argumenents) the "monkeying".But the motion of the atoms is different, physically, from the energy level transition of their electrons that are being used to define the time standard (by way of the frequency of the photons associated with the transition). So even if we are going to monkey with the definition of "motion" to mean "any change with time", we still have to be careful not to confuse one change with another.
This ad hominem response is completely inappropriate and unwarranted.Maxila said:Because I doubt your sincerity, and ability to be objective
