How does Sodium acetate react with water?
  • Thread starter Saba
    Water
4 replies · 3K views · last reply
Saba
TL;DR
When sodium acetate CH3COONa reacts with water does it form hydroxide ions, leaving the neutralised solution alklain?
Chemical equation: CH3COO⁻Na⁺(aq) + H2O(l), with sodium acetate in aqueous solution and liquid water on the left side.
Removes a 'proton' from the water molecule. You might think of it like, CH3COO-is the anion of a weak acid and Na+ is the cation of a strong base. Sodium acetate dissolved in water would if conc. is high enough, make the solution alkaline.
Congratulations, you just discovered process of hydrolysis :wink:
Yes, that's what is happening:
CH3COO- + H2O ↔ CH3COOH + OH-
You might want to read on Brønsted–Lowry acid–base theory, this reaction is an important part of it.
0.01M solution of sodium acetate has a calculated pH of 8.4, you don't need high concentrations for the effect to be easily observable.
Some fading of precise knowledge has been happening the last several years. (That is, in my knowledge)
