How Does the Logarithmic Function Affect Contour Integrals Around Infinity?
pantboio
Consider the function
$$f(z)=Log(\frac{z-a}{z-b})$$
where $a,b\in D(0,r)$ , the disc of radius $r$ centered at the origin, open, and $r>0$. Show that $f$ is holomophic in an open subset of complex plane, containing the complement of the disc:$\mathbb C-D(0,r)$ and compute the integral
$$ \oint_{|z|=r}z^nf(z)dz$$
where $n\geq 0$ is an integer.
I'm quite confused about this problem. Because, the $Log$ in the RHS should be the principal branch, i.e. $Log(z)=log|z|+iArg(z)$, with $Arg(z)\in (-\pi,\pi)$ and $Arg(0)=0$. Then i should prove that $\frac{z-a}{z-b}$ does not intersect the real negative axis, but how to do this? However, suppose i could prove the holomorphicity, then I'm left to compute the integral, for which i tought to use the residue formula applied to $\infty$ point, so calling $I$ the integral,
$$I=2\pi i Ind(\gamma,\infty)Res(f,\infty)$$
where $\gamma$ is the contour $|z|=1$, so that $ind(\gamma,\infty)=-1$. But then the computation of residue is very hard for me. Some help?
Re: contour integral around $\infty$
maybe i solved the first part, noticing that
$$Arg(\frac{z-a}{z-b})=Arg(z-a)-Arg(z-b)$$
and the RHS is the angle between $z-a$ and $z-b$, so points such that $\frac{z-a}{z-b}$ lie on the negative real axis are those for which holds
$Arg(\frac{z-a}{z-b})=\pi$
which is the segment joining $a$ with $b$. Hence, taking $z$ with $|z|>Max(|a|,|b|)$ I'm sure that $\frac{z-a}{z-b}$ is not a negative real number
Also this post is very interesting!... and also hiding some traps!... proceeding 'step by step' first we remember the McLaurin expansion...
$\displaystyle \ln (z-a) = \ln (-a) - \sum_{n=1}^{\infty} \frac{z^{n}}{n\ a^{n}}$ (1)
... and the series (1) converges for |z|<|a|. Because is...
$\displaystyle f(z)= \ln (z-a)- \ln (z-b)$ (2)
... we obtain that f(z) is holomorphic for $|z|< \text {min}\ (|a|,|b|)$ and, almost immediate consequence, for $r< \text {min}\ (|a|,|b|)$, is...
$\displaystyle \oint_{|z|=|r|} z^{n}\ f(z) = 0$ (3)
What happens for $r> \text {min}\ (|a|,|b|)$ will be examined in next posts... Kind regards $\chi$ $\sigma$
maybe i have a proof. I simply factorize $z$ instead of $a$ in $z-a$. So: $Log(z-a)=Log(z(1-\frac{a}{z}))=Log(z)+Log(1-\frac{a}{z})$, and similarly for $Log(z-b)$. Summarizing we have
$$Log(\frac{z-a}{z-b})=Log(z)+Log(1-\frac{a}{z})-Log(z)-Log(1-\frac{b}{z})$$
which holds for $|z|>a,b$, as we wanted,and so..
$$\ldots=\sum_{n=0}^{\infty}\frac{a^n}{z^n} -\sum_{n=0}^{\infty}\frac{b^n}{z^n}$$
Hence we get
$$z^nLog(\frac{z-a}{z-b})=z^n (-2-\frac{a-b}{z}-\frac{a^2-b^2}{z^2}\ldots)$$
we are interested in the coefficient of $\frac{1}{z}$, which is $-(a^{n+1}-b^{n+1})$, but with the signum $+$, since we are looking for residue at $\infty$, not at $0$.
Conclusion: the integral is $2\pi i$ times $a^{n+1}-b^{n+1}$ times the winding number of $\infty$ with respect to the contour, which is counterclockwise oriented, so -1.
$$\ldots=\sum_{n={\color{red}1}}^{\infty}\frac{a^n}{{\color{red}n}z^n} -\sum_{n={\color{red}1}}^{\infty}\frac{b^n}{{\color{red}n}z^n}$$
Hence we get
$$z^nLog(\frac{z-a}{z-b})=z^n (-\frac{a-b}{z}-\frac{a^2-b^2}{{\color{red}2}z^2}\ldots)$$
we are interested in the coefficient of $\frac{1}{z}$, which is $\color{red}{-\dfrac{a^{n+1}-b^{n+1}}{n+1}}$, but with the signum $+$, since we are looking for residue at $\infty$, not at $0$.
I think that is correct, except that you have left out the coefficient $1/n$ in the $n$th term of the power series (see the bits in red above). Also, the power series starts with the term $n=1$, not $n=0$.
Hence we get
With the exception of some minor details that have been adjusted, Your solution is very good!... we have...
$\displaystyle f(z) = \ln \frac{z-a}{z-b} = \ln (1-\frac{a}{z}) - \ln (1- \frac{b}{z}) = - \sum_{k=1}^{\infty} \frac{a^{k}}{k\ z^{k}} + \sum_{k=1}^{\infty} \frac{b^{k}}{k\ z^{k}}$ (1)
What is important to say is that f(z) is the sum of two Laurent expansions and the convergence condition is $\displaystyle |z|> \text{max} (|a|,|b|)$, and if it is satisfied we easily obtain that...
$\displaystyle \oint_{|z|=r} z^{n}\ f(z)\ dz = 2\ \pi\ i\ \frac {b^{n+1} - a^{n+1}}{n+1}$ (2)
Very well!... we have computed the integral for $\displaystyle r< \text{min} (|a|,|b|)$ and $\displaystyle r> \text{max} (|a|,|b|)$... but what does if happen in other cases?...
Kind regards
$\chi$ $\sigma$
If we suppose that |b|>|a| [if not we swap b and a of course...], then the only controbution to the integral is given by... $\displaystyle f_{a} (z) = \ln (z-a) = \ln z + \ln (1-\frac{a}{z}) = \ln z - \sum_{k=1}^{\infty} \frac{a^{n}}{n\ z^{n}}$ (1)
The controbution of the second term of (1) has been already computed, so that we have to find the integral... $\displaystyle \oint_{|z|=r} z^{n}\ \ln z\ dz$ (2)... where |a|< r < |b|. Setting $\displaystyle z= r\ e^{i\ \theta}$ we have... $\displaystyle \oint_{|z|=r} z^{n}\ \ln z\ dz = i\ r^{n+1}\ \int_{- \pi}^{+ \pi} (\ln r + i\ \theta)\ e^{i\ (n+1)\ \theta}\ d \theta = 2\ \pi\ i\ r^{n+1}\ \frac{(-1)^{n+1}}{n+1}$ (3)
... so that for |a|< r < |b| is...
$\displaystyle \oint_{|z|=r} z^{n}\ f_{a}(z)\ dz = 2\ \pi\ i\ \frac{(-1)^{n+1}\ r^{n+1} - a^{n+1}}{n+1} $ (4)Kind regards
$\chi$ $\sigma$
