How does the PF Username Game work?
  • Thread starter Thread starter Gokul43201
    Game
141 replies · 17K views
An incredibly difficult one, perhaps:
31. What the lookout in the crow's nest yelled, when a very distant radio beacon appeared in his telescope
And here's a final one, for fun.
32. Get to the point
16. "No, not any!" he rages.
Hootenany?
Tiny Tim?
Hootenany?
Too many n's
Probably not "Danger," if it was very distant
And now, to help with the harder ones, here's a little something extra.
PLEASE READ VERY CAREFULLY
All the answers to the clues fit in the Crossword grid provided below, in unspecified locations. What you now get to do is one or both of two possible things:
1. You can call the locations where you think already solved answers should go. The locations on the grid are referenced by numbers which mark the position of the starting letter of each answer. Furthermore, to indicate whether the answer fits horizontally/across (A) or vertically/down (D) you append A or D to the grid number.
So, for instance, you can make the following call: 1: Berkeman goes into 6A (naturally this would be a bad call, since 6A is for a 5-letter-word, which "berkeman" isn't)
There are limitations imposed here too. You are entitled to a maximum of 5 good calls or 2 bad calls (whichever happens first). Once you reach either limit, you may no longer make calls on grid positions, but you may still continue to solve unsolved clues (see below), as long as you don't hit the separate limit for solving clues. Because of the limitation on bad calls, you may only make 1 or 2 calls at a time (depending on whether you have 2 or 1 unused bad call chances).
2. You can solve clues, just as before. The existing limitation of 4 correctly solved clues still holds (unless you've returned from a time-out, in which case, it is now 3 correctly solved clues). If you hit the limit on solving clues, or even otherwise, you can continue to call grid locations, so long as you haven't hit that separate limit (described above).
http://img178.imageshack.us/img178/3654/fixedyt7.png
And here's the list of solved answers (and unsolved clues), with their clue numbers:
Code:
1. Berkeman
2. Moonbear
3. kurdt
4. Astronuc
5. lisab
6. Vanesch
7. MIH
8. Zapper
9. Ivan Seeking
10. Redbelly
11. mgbphys
12. Evo
13. hypatia
14. Borek
15. Cristo
16. Hootenanny
17. artman
18. Andre
[b]19. Antonius, who wanted your aures.[/b]
20. LowlyPion
21. matthyaouw
22. Chi Meson
23. Jimmysnyder
24. Vanadium
[b]25. Other AZ Sen. follows chariot racer's dad?
26. Heels broke in the afternoon - returned.[/b]
27. Edward
28. Proton Soup
29. mathwonk
[b]30. Meh ... cooties is gone, somehow.[/b]
[b]31. What the lookout in the crow's nest yelled, when a very distant radio beacon appeared in his telescope[/b]
32. tiny tim
I will periodically check people's calls, tell you which ones were good or bad, and update the grid accordingly.
All clear? Go.
Hootenany?
Correct. But it is spelled Hootenanny. So that's one more down.
NeoDevin said:
Tiny Tim?
Easy pickings, eh? Correct.
Yeah, what he saw was really, really distant.
Gokul43201 said:
21. Same clue as 10, strangely
matthyaouw, anagram of clue 10.
Gokul43201 said:
17. In part, M and N are the middle letters.
Artman?
This one is a guess, Art = in part, man has M and N.
NeoDevin, good work on 21.
Artman is also the correct answer (guessed by kurdt, a while ago), but the explanation is way simpler.
It's a simple hidden clue: part m and n
Gokul43201 said:
NeoDevin, I need explanations.
I edited my posts with explanations.
NeoDevin said:
I edited my post...
So Did I. :biggrin:
Gokul43201 said:
So Did I. :biggrin:
And here I thought I was being subtle :wink:
Question about the crossword puzzle: Do we include spaces?
No. Do not include spaces or other separators that are found in the username.
Eg: Ivan Seeking becomes IVANSEEKING, one continuous 11-letter word.
Ouch! Found a mistake in the grid. Will have to redo it. Most of the existing grid is correct though. So, if you want to make any calls now, I will count them and enter them in the new grid - you don't have to wait for me to fix it. You will not, naturally, be penalized for a mistake I've made.
Will be replacing old grid with new grid at 4:50pm EST (in 2 minutes).
EDIT: Grid is fixed. We are all set now.
Hurkyl: kyl = other AZ Sen., chariot racer's dad = Hur (As in Ben Hur?)
Nice one. Not taking any shots at the grid?
I'm thinking about it.
25 Down, MIH
28 Across, jimmysnyder
11 Down, Evo
13 Across, Lowly Pion
14 Down, Ivan Seeking
Edit: I would keep going, but you said to stop after 5.
All correct.
You're all out of grid calls and have 1 (or 2?) left for clue cracking.
The grid will be updated in a bit.
I don't have any ideas yet for the rest of the clues, but I'll think on them.
UPDATED GRID:
http://img523.imageshack.us/img523/4999/grid2vf5.png Updated list of solved / filled (#) answers (and unsolved clues), with their clue numbers:
Code:
1. Berkeman
2. Moonbear
3. kurdt
4. Astronuc
5. lisab
6. Vanesch
7. MIH #
8. Zapper
9. Ivan Seeking #
10. Redbelly
11. mgbphys
12. Evo #
13. hypatia
14. Borek
15. Cristo
16. Hootenanny
17. artman
18. Andre
20. LowlyPion #
21. matthyaouw
22. Chi Meson
23. Jimmysnyder #
24. Vanadium
25. Hurkyl
26. mheslep
27. Edward
28. Proton Soup
29. mathwonk
31. CaptainQuasar
32. tiny tim
That's the point of the crossword grid - it will help with the hard ones that are left. But I made the grid somewhat sparse, so it doesn't provide too much help.
26 down: Edward
You forgot to add the answer to 25 on the list.
CaptainQuasar, The lookout yells for the captain, to report a distant radio beacon, a quasar?
lisab said:
26 down: Edward
Correct!
Thanks - fixed now.
Brilliant! Very nicely done.
Edit: Grid and answers edited into post above.
