How does the size of He- compare to that of a neon atom?
The He- ion is definitively larger than the Ne atom due to its lower electrostatic attraction, resulting from having fewer protons. As the discussion clarifies, while both He- and Ne occupy the same energy level, the reduced number of protons in He- allows its electrons to be less tightly bound to the nucleus. This trend in atomic size is consistent across the periodic table, where atomic radius increases down a group and decreases across a period, with noble gases being the smallest atoms within their respective periods.
  • Understanding of atomic structure and electron configuration
  • Familiarity with periodic table trends
  • Knowledge of electrostatic forces in atomic interactions
  • Basic concepts of ionization and ionic size
  • Research the periodic trends in atomic size across different groups and periods
  • Study the concept of electrostatic attraction and its effect on atomic radius
  • Explore the differences between ions and neutral atoms, focusing on size comparisons
  • Investigate the properties of noble gases and their position in the periodic table
Chemistry students, educators, and anyone interested in atomic structure and periodic trends will benefit from this discussion.
wee00x
I understand that He- is larger than He, but I don't know which is bigger between He- and Ne.. please help??
Does anyone know the answer to this? How does the He- ion compare in size to that of the Ne atom?? How can you tell which one is bigger?
First, compare the size of He- with that of Li. Second, compare Li with Ne. What is the general trend in atomic size within each row of the periodic table?
Oh I see.. Well I understand the trends but I don't understand why it is that way. Do you have a explanation that can clear it up??
Just to make sure we are on the same page, explain the trends the way you understand them.
Well as you go down the periodic table, the size of the atoms will increase because of the addition of higher energy levels, increasing atomic radius. However, when you go across the periodic table to the right, the electrostatic force between electrons causes them to become more compact and smaller. However, once the energy level is completely filled with electrons, the atom (noble gas) is larger.
I agree with everything except the last sentence. There is no reason for the noble gas atoms to break out of the general scheme. They are the smallest atoms within a period. However, between a noble gas atom of one period and the alkali metal of the next period, the radius rises sharply, because the next period starts a new electron shell.
So would the He- be larger than the Ne atom, since it would be on the some energy level, but farther to the left on the periodic table?
Would it be larger or smaller than neutral Li?
neon would be smaller than lithium. Does this mean that He- would be larger than neon?
I did not express myself clear. Would He- be larger or smaller than Li?
I imagine that the helium ion would be smaller... because it has less protons than lithium does... but there is also the fact that since there are less protons than lithium, there is less electrostatic attraction, and so the electrons are not held in as close for the helium ion. I feel that this more likely explains why a helium ion is not likely to stay as an ion for very long. Am I correct?
Yes, you are thinking correctly. It will be larger than Li EXACTLY for the same reason Li is larger than Be.
Okay, thank you for helping me clear that up! So He- is larger than Ne because although they are on the same energy level, He- has less of an electrostatic attraction, being that it has less protons, and so the electrons are not bound as tightly to the nucleus as they would be with Ne.
  • · Replies 0 ·
12K
