How Does Viète's Formula Apply to Trigonometric Products?
  • Thread starter Thread starter ehrenfest
13 replies · 3K views
ehrenfest
[SOLVED] another Viete problem
Prove that for every positive integer n,
[tex]\Pi_{k=1}^n \tan \frac{k \pi}{2n+1} = \sqrt{2n+1}[/tex]
http://en.wikipedia.org/wiki/Viète's_formulas
I cannot figure out what polynomial I need to apply Viete to.
Should I let
[tex]f(x) = \Pi_{k=1}^n \left(x- \tan \frac{k \pi}{2n+1}\right)[/tex]
? That doesn't seem to help at all. I looked for relevant trig identities and couldn't find any. I tried induction (the case n=1 is trivial) but that failed also so alas I am stuck again. :(
tiny-tim said:
Hint: use de Moivre's theorem. :smile:
Hmm.
[tex]\cos n \theta (1 + i \tan n \theta) = (\cos \theta + i \sin \theta)^n[/tex]
We can let \theta = pi/(2n+1). We could then sum both sides over n. But somehow we need to get a polynomial and then apply Viete to it. I don't see what polynomial to use. Sorry tiny-tim. :(
ehrenfest said:
Hmm.
:cry: (tears hair out) :cry:​
But the whole point of de Moivre's theorem is that it avoids using Viete! :rolleyes:
Just do what you said … sum kπ/(2n+1) from 1 to n. :wink:
ehrenfest … you keep doing this … you get it fixed in your head that you have to do something, even when you yourself have found a way that avoids it! :smile:
Well I really didn't see how anything would simplify after I summed it:
[tex] \sum_{k=1}^n \cos \frac{k \pi}{2n+1} (1 + i \tan \frac{k \pi}{2n+1} ) = \sum_{k=1}^n (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^k[/tex]
But I'm sure you have some clever trick up your sleeve tiny-tim.
George Jones said:
[tex]\cos \theta + i \sin \theta = ?[/tex]
[tex]e^{i \theta}[/tex]
But how does that help simplify the RHS. I know there must be something obvious I am missing? It is just the first n of the 4n+2 roots of unity but does that equal something nice?
But how does that help simplify the RHS?
Substituting this shows that this series is a special type of series.
What type of series?
I'm an idiot.
The RHS is
[tex]\frac{1-\exp \frac{i (n+1) \pi}{2n+1}}{1-\exp \frac{i \pi}{2n+1}}[/tex]
So
[tex] <br /> \sum_{k=1}^n \cos \frac{k \pi}{2n+1} (1 + i \tan \frac{k \pi}{2n+1} ) = \frac{1-\exp \frac{i (n+1) \pi}{2n+1}}{1-\exp \frac{i \pi}{2n+1}}<br /> [/tex]
Sorry to keep prolonging this but I still don't see where this is going. I mean how are we ever going a product of tangents from this!
Hi ehrenfest! :smile:
You're getting confused.
You've used ∑ instead of ∏. Your:
ehrenfest said:
[tex]\sum_{k=1}^n \cos \frac{k \pi}{2n+1} (1 + i \tan \frac{k \pi}{2n+1} ) = \sum_{k=1}^n (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^k[/tex]
should be: [tex]\Pi_{k=1}^n \cos \frac{k \pi}{2n+1} (1 + i \tan \frac{k \pi}{2n+1} ) = \Pi_{k=1}^n (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^k = (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^{\sum{k=1}^{n} k}\\,=\,...[/tex]
hmm … the LaTeX hasn't come out right … but I hope you see what I mean! :redface:
You've used ∑ instead of ∏. Your:should be: [tex]\Pi_{k=1}^n \cos \frac{k \pi}{2n+1} (1 + i \tan \frac{k \pi}{2n+1} ) = \Pi_{k=1}^n (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^k = (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^{\sum{k=1}^{n} k}\\,=\,...[/tex]
Well you said sum in post #4. Sorry I still don't see where we are going with this. I agree with what you posted above and the sum of the first n integers is n(n+1)/2 but I cannot even see what will happen in the case of n=2.
Then we have
[tex]\exp i \frac{3 \pi}{5} = \cos \frac{\pi}{5} \cos\frac{2 \pi}{5}(1+i\tan \frac{\pi}{5})(1+i\tan\frac{2\pi}{5})[/tex]
We can take the real part of both sides but then what?
ehrenfest said:
… the sum of the first n integers is n(n+1)/2 but I cannot even see what will happen in the case of n=2. …
ah, but if you use de Moivre again, then the n+1 cancels, and you get … ? :smile:
What? There is a 2n+1 not an n+1 in the denominator of the cosine and the sine...
Well, this was really bothering so I looked at the solution in my book that employs Viete. Using de Moivre was a good idea but I think you really do need Viete also.
