How far a cube sinks below the waterlevel
  • Thread starter Thread starter justinram22
    Cube
The discussion revolves around a physics problem involving a wood cube with a density of 700 kg/m^3 floating in water. For part (a), the user successfully calculates the distance from the top of the cube to the water surface but struggles with part (b), which requires determining the mass needed to make the cube's top level with the water. The user attempts to apply the buoyancy equation but arrives at an incorrect mass of 27 kg, while the solution in the textbook states 8.9 kg. Additionally, the user inquires about the weight of a cube of water with the same dimensions, indicating confusion about the calculations. The thread highlights common challenges in understanding buoyancy and density in physics problems.
justinram22
A wood cube .30m on each side has a density of 700 kg/m^3 and floats levelly in water. (a) What is the distance from the top of the wood to the water surface? (b) What mass has to be placed on top of the wood so that its top is just at the water level.
I assume the buoyancy equation.
I figured out part (a) no problem, but seem to be having difficulty with part (b).
I assume it has to be:
Density=(mass/volume)?
When i do that I get 18.9, where the back of the book says 8.9
Thanks guys so much! Hope once I actually get good at physics I can come back and help people similar to myself!
How much would the wooden block weigh if its density was the same as the density of water?
Sorry, but I'm still lost?
So
1000=(mass/.027)
mass=27?
Thanks!
27 what?
27kg
Which is not what they had in the back of the book (they had 8.9).
Thanks You again!
How much does a cube of water weigh which is 0.30 m on each side?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
