How Far Does the Camera Fall Before the Skydiver Catches It?
76 replies · 8K views · last reply
Vaz17
Hey guys
need help beginning to solve the following:
A skydiver accidentally drops a camera out of the plane. The diver notices the mistake 3.0s later and dives out of the plane with a downward velocity of 10.0 m/s. The camera experiences free fall(9.8 m/s^2), but the sky diver accelerates downwards at 8.0m/s^2.
How far does the camera fall before the sky diver is able to catch it?
I found how far the camera falls in 3.0s= 44.1 m, and Vf of the camera is 29.4 m/s [down] since Vi is 0. I Don't know really where to go from here, any help will be appreciated!
i think the teacher mentioned it takes 39 seconds, but how would i find that
What is true about the displacement when the diver meets the camera?
so i need to do d=motion equation of camera=motion equation of diver?
If you've done it correctly you should get a quadratic
ok thank you
but how do i deal with the 10m/s and the 8.0 m/s^2 when deriving the divers motion equation? they can't simply be added together can they?
I am assuming that you are using [tex]y=v_{i}t+ \frac{1}{2}at^{2}[/tex] where y is the vertical displacement
Okay so setting 2 equations equal gives [tex]v_{i1}t+ \frac{1}{2}a_{1}t^{2}=v_{i2}t+\frac{1}{2}a_{2}t^{2}[/tex] which gives the quadratic [tex](v_{i1}-v_{i2})t+(a_{1}-a_{2}t^{2})t^{2}=0[/tex]
So no magic happens =)
Its up to you to decide which root is relevant
edit I left out my 1/2
ok so what can i derive from that without t
edit where did you leave out the 1/2
1) I placed the 1/2's that you see in the equation.
2) no t's should disappear since your velocities and accelerations are different
A simple approach when comparing different velocities is using a table. Of course, I highly recommend working out the mathematics, but a table should also give you the same answer. Example: Car 1: 1s=30m, 2s=50m...Car 2: 1s=45m, 2s=49m...See where they interesect, which is like wording out a quadratic, so-to-speak.
Regards,
Fragment
The solution seems pretty clear to me from this point, djeit pretty much pointed it out. Either graph your quadratics, solve them algebraically, or use the table method.:smile:
Fragment
ok, I found the time, 4.5s, using the quadratic formula. it seems wrong, and once i have this time, how do i get displacement?
which variables do i plug into the displacement formula? my starting values?
no i did not add the 3 seconds...i was just showing the answer to the quadratic...remember [tex]\frac{-b+/- \sqrt{b^{2}-4ac}}{2a}[/tex]
lol i think you misunderstood, i didnt know how to solve the equation you gave on pg 1
LaTeX Code: (v_{i1}-v_{i2})t+(a_{1}-a_{2}t^{2})t^{2}=0
when i plug in the values for this, i get 37.2...:S
In that case, you should create a post in the math forum asking how to solve a quadratic equation. Also you did not read my equation carefully as the result is not a single number.
You should fix your LaTeX code though, it would help me read what you plugged in. After that we might be able to see where you struggle.
Regards,
Fragment
no i know how to solve a quadratic, I am just confused with your equation, i think that's the basis of my whole incorrect solution right now lol.
fragment, that code was for djeitnstine's equation on pg 1.
