How far will this block travel when launched on the floor?
  • Thread starter Thread starter Mbaboy
    Block Travel
The discussion revolves around determining the distance a wooden block will travel when launched with an initial velocity of 11.3 ft/s across a floor. The participants struggled to measure acceleration due to the lack of constants and testing methods. They identified the kinematic equation x = v_0 t + (1/2) a t^2 as essential for calculating distance, but faced discrepancies in their experimental results, with calculated distances significantly lower than actual measurements. The key takeaway is the importance of accurately measuring acceleration, which is influenced by friction, to achieve reliable results.
  • Understanding of kinematic equations in physics
  • Knowledge of initial velocity and its impact on motion
  • Familiarity with concepts of acceleration and friction
  • Basic skills in experimental data collection and analysis
  • Study the effects of friction on motion using different surfaces
  • Learn how to accurately measure acceleration in experimental setups
  • Explore advanced kinematic equations and their applications
  • Investigate methods for measuring initial velocity in practical experiments
Students in physics, educators teaching kinematics, and anyone interested in experimental physics and motion analysis.
Mbaboy
I consider myself good in physics, but I was unable to figure this problem out after working on it for almost an hour and a half. I approached it many different ways, but I always hit a dead end or a solution I knew was wrong.
Our teacher gave us a wooden block, a meter, stick, and a timer. He gave us no constants. We were asked to determine how far the block would travel across the floor if it were launched with an initial velocity of 11.3 ft/s on the floor.
The main problem was we couldn't test the block with different initial velocities because there was no way to measure it. We were given half an hour, and with time running out we decided the best way to do it was launch it with an unknown initial velocity and record the distance and time. Therefore, if the final velocity, displacement, and time are known, theoretically one could solve for acceleration. The problem is I couldn’t no matter what models I used to find acceleration.
Thinking back on it, if I had throw the block a certain distance and measured that distance and time I could have obtained the initial velocity, and let it slide afterwards to get a displacement and another time. It seems too complicated though. Any help?
The key, as you seem to realize, is to somehow measure the acceleration. The acceleration, which depends on the friction, will be the same for any speed. What's a simple kinematic relationship between distance, time, and acceleration?
x = vt + at^2
I first tried to use that and calculate the quadratic fuction on my calculator. It wasn't right though because its not quadratic if velocity is changing.
The proper equation is:
But if you view the motion backwards, then you can take v_0 = 0.
Sorry, my last post was sloppy. That was the equation I used.
But when I did that, my a=9 ft/s/s which gives the distance as about 8 feet. The actual distance was about 45 feet.
Normally, I would conclude my experimental data is off, but its seems way too off.
  • · Replies 47 ·
  • · Replies 18 ·
