How Fast Could a Car Ascend a Straightened Mountain Road?
The discussion revolves around determining the time it would take for a car to ascend a straightened mountain road, originally characterized by a slope of 6.4%. The car starts from rest and has a top speed of 203 mph, with an average acceleration of 2.93 ft/s². The original course length is noted to be 12.42 miles with numerous turns, raising questions about how this distance changes when considering a straight ascent.
  • Participants discuss various methods to calculate the time to reach the top, including equations for distance and time based on acceleration and final velocity. Some express uncertainty about the relevance of the slope and whether the given acceleration applies throughout the ascent or only until the car reaches its top speed.
The conversation is ongoing, with participants seeking clarification on assumptions regarding acceleration and the impact of the slope. Some have shared their calculations, while others have requested to see the original poster's work to identify potential errors. There is no clear consensus yet on the correct approach or interpretation of the problem.
Participants note the ambiguity in the problem statement, particularly regarding the relationship between the average acceleration and the slope of the hill. There is also confusion about whether the maximum speed is reached before the top of the hill or if the car continues at that speed after reaching the summit.
  • #31
ingenius1 said:
then i guess you can't answer that problem then, can you?
He's is not trying to do your homework for you. He's trying to help you. Politely keep that in mind, please.
  • #32
Could we assume that in this case 203mph is reached at the moment the car crosses the finish line and consider it Vf..? Could the time from "a" to "b" be determined then...?
  • #33
there's Pikes Peak. No curves..forget curves...straight shot from point A to point B...with an incline of 6.4% thrown in that line
  • #34
BTW..fastest time ever ran is 7:57..That's through the whole 12.42miles...Just FYI if curious...nuthin to do with the problem...👍
  • #35
The problem statement, as written, has a few ambiguities in it. The main one regards what is meant by "if we removed all the curves ... ."
Interpretation A:
Keep the 3-dimensional starting location and finish location exactly where they are, and then draw a new, straight line between them, and that is the new track.
However, this will increase the slope above 6.4 %, if that even matters.
Without knowing more information the relative position between the starting location and finish location, there isn't enough information to solve this problem, in this interpretation.
Interpretation B:
Grab the starting position and pull it out horizontally until the track becomes a taught, straight line. In this interpretation, the length of the track is still 12.42 miles and the slope is still 6.4% (if the slope even matters).
Other ambiguities:
The maximum acceleration is specified as 2.93 \ \mathrm{\frac{ft}{s^2}}. But is this the maximum acceleration with respect to the road when climbing a 6.4% slope, or 2.93 \ \mathrm{\frac{ft}{s^2}} total?
You see, initially when the vehicle is accelerating, it will be fighting the acceleration of gravity somewhat due to the fact that it's on a slope. Should this be taken into account, or is it already taken into account in the 2.93 \mathrm{\frac{ft}{s^2}} specification?
Also, I looked up the Pikes Peak International Hill Climb. Its track length is 12.42 Miles with an elevation change (from start to finish) of 4725 ft. That produces an average slope gradient of 7.22%, although this problem says to use only 6.4%, and honestly, I'm not certain whether the slope is relevant to solving this problem at all, given the other ambiguities.
  • #36
If I had to guess though (and this is just a guess -- I could be wrong), ignore the slope altogether, and just treat this problem as a car driving on a straight, level, 12.42 mile track.
The vehicle accelerates at 2.93 \ \mathrm{{\frac{ft}{s^2}}} until it reaches its top speed of 203 mph. After that, it continues at 203 mph until reaching the finish line.
But that's just my guess. The question is ambiguous enough such that there's a good chance my interpretation is wrong.
  • #37
Guess the author of this problem expects for the "made up or not slope" of 6.4% to be considered...just go with it..he didnt include friction nor mass throughout the slope so assume the given acceleration is "average" as stated from Zero to 230mph at finish all throughout the incline...you guys are getting way to complicated...I'm surprised you guys haven't questioned if the driver has checked the proper PSI on the tires..😁
  • #38
An "average" acceleration is of little use. The distance covered in a given time with a front-loaded acceleration will be greater than that covered in a given time with a more constant acceleration, even though the "average" is the same in both cases.
  • #39
Ok maybe I am going to be wrong to put it this way but seems that distance traveled is unimportant here to the original author..what if he just wants to know Time from a to b at with that given acceleration and the made up or not slope to add to the fun...and could care less how far the car actually traveled to reach the 203mph at the end..if that average acceleration doesn't change can it eventually reach the 203mph?
  • #40
I am thinking that at a 6.4% slope the straight road would be longer than the curved road.
Possibly 73916.5 feet or 13.999 miles long.
I used a right triangle with a height of 4721 feet and calculated a base of 73765.625 feet based on the height and slope. Then Pythagoras did the rest.
  • #41
For what it's worth, the actual, real-world track length is 12.42 miles. That's one detail that matches the problem description given here.
But that's not the displacement between the two points, it's the total distance, which includes curves, hills, and all. The real-world displacement will is significantly shorter than 12.42 miles, not longer.
If your approach is to find the straight-line displacement of the real-world start and finish locations, you will need to look up their GPS coordinates on the Internet (presumably), and use geometry to calculate their 3-dimensinal displacement (and effective slope, if that's even relevant.) Keep in mind that these necessary details were not given in the problem statement, as it was described. This leads me to believe that this is probably not the approach the author of the problem intended. (Then again, this problem statement is so full of ambiguities, it's anybody's guess.)
  • #42
I interpreted the slope given in the problem (6.4%) as a constant. A constant which would have to be ignored in order to use straight line displacement. This is not homework, it is a qualifying question for a contest.
here is the text;
The fastest time ever run at Pikes Peak is 7:57. That’s way too long. If we removed all the curves, making a straight line from top to bottom, how quickly could a Challenger SRT® Hellcat Redeye reach the top?
ProTips
Slope of 6.4%
Redeye top speed 203 mph
A stock Redeye has a peak acceleration of over 1g. Assume this Redeye will accelerate at an average of .091 g (2.93 ft/s2)
The 12.42 mile long Pike’s Peak course has over 156 turns
What you might need:
A calculator
The internet (unit conversions)
A smart friend
Some kinematic equations:
d=v^2/2a
t=v_f/a
t=d_remaining/v_f
  • #43
About 12 minutes, including turns.
  • #44
fyithis is next...im coming up with 43,446 HP...i think i might be missing a proper conversion...
  • #45
this is the answer to the previous problem
  • #46
So quite easy once it is explained that the straightening of the road was supposed to preserve the length, not the slope - despite that in the question statement the slope is given prominence, while the distance seems to be just background on the actual course.
  • #47
yep..wouldve saved us all a bunch of headaches...
  • #48
Although the 6.4% slope is re-iterated on the solution slide, it is never actually used in the calculation. Despite the prescription of the 0.91 g acceleration being average, the proffered calculation treats it as constant instead.
  • #49
The problem - as given - would barely qualify as a primary school homework assignment.
As stated earlier, the actual time for the run was about 12 minutes : 60mph average, give or take.
It might be interesting to use the car and tire specs, and include the slope, hairpins, and road-surface data. But, mostly that would just show up the car and tire companies' marketing figures, which are as far removed from "real world, with non-pro driver, an underinflated left rear tire, 2 kids arguing in the back seat, etc." as the stick-figure physics problem.
  • · Replies 19 ·
12K
  • · Replies 21 ·
13K
9K
