How increased mass and drag affect speed
1 reply · 3K views · last reply
rc1234
Hello. I read an article about aerodynamics.
http://www.cyclist.co.uk/in-depth/2873/fat-v-skinny-who-goes-downhill-faster
I'm a little bit confused with this statement regarding mass, drag, and velocity:
"When you increase the mass the speed increases by cubic function, whereas if you increase the aerodynamic drag the speed decreases by a square function. Hence why cyclists who are heavier can go faster"
I get the relationship between the aerodynamic drag and speed based on the Drag equation
Drag = 0.5 coefficient * rho * v^2 * A so v = sqrt(2mg/coefficient*rho*A)
However, I'm not sure where the cubic function for the mass and speed relationship was taken. Can someone tell explain this to me? Thank you.
Do you ? I find the wording in the link utterly confusing. Key is in
Terminal velocity is the speed at which aerodynamic drag counters the force of acceleration
Downhill acceleration force is ##mg\sin\alpha## if the slope angle is ##\alpha##. So if you put a cylinder with mass ##m## and frontal area ##A## on a saddle and let it coast downhill, the contraption will reach some terminal velocity ##v_t##. Make the radius 10% bigger and the area will increase by 10%. But the mass will increase by 20%, so the equilibrium "downhill force = drag force" allows an in crease of 5% in ##v_t## (if the coefficient doesn't change).
And right you are there: heavier folks generally are not lighter folks enlarged in three directions.
Further down the link is also confusing: the tandem bicycle has double the force and about the same air resistance on a horizontal road.
