How inverse square law is derived from area of sphere
The discussion centers on the derivation of the inverse square law from the area of a sphere, specifically examining the role of the constant 4π in various contexts such as gravitational and electromagnetic forces. Participants explore the mathematical relationships and assumptions underlying these laws, including the implications of the area formula 4πr².
  • Some participants express confusion about the role of the constant 4π in the inverse square law, questioning whether it cancels out in certain equations.
  • Others explain that in electromagnetism, the inverse square law is derived from Gauss's law, where the electric field strength decreases with the square of the distance, incorporating the 4π term into the constant.
  • A participant notes that the gravitational constant G is defined with the 1/4π already applied, suggesting that the constant is simply a matter of convention.
  • Some participants propose that the 4π in gravitational equations appears in the context of the area of a sphere, but its absence in the gravitational force formula complicates explanations of the inverse square relationship.
  • There is mention of the ratio of areas of spheres at different radii to illustrate how intensity diminishes with distance, reinforcing the inverse square relationship.
  • Participants discuss the idea that constants like G could be defined differently without affecting the underlying physics, as they are ultimately measured quantities.
Participants do not reach a consensus on the role and significance of the 4π term across different contexts. While some agree on its mathematical implications, others remain uncertain about its presence in gravitational equations and its conceptual meaning.
There are unresolved questions regarding the assumptions made about the constants in the equations and how they relate to the physical interpretations of the inverse square law. The discussion also highlights the dependence on definitions and the historical context of these laws.
Ebenshap
I almost understand how the inverse square law is derived from the area of sphere equation, 4πr2, but I'm not quite clear on what happens to the 4π. I found one equation that seemed to say that the intensity is equal to the area of the sphere of the source point times the amount of whatever coming from that source point, divided by the area of the sphere at the distance one is interested in. So that way the 4π cancels out since it's common to the numerator and denominator. Is that right? If so, does that mean that the radius of the source point is always assumed to be 1?
What context are you speaking of? For instance, in electromagnetism, it was historically postulated that the electrostatic force obeys an inverse-square law, and this was based off of experiment. We can then draw assumptions from that. For instance, I don't know your background, but if you're in college, you may know of Gauss's law for electrostatics: [tex]\oint \mathbf{E} \cdot d\mathbf{A} = \frac{Q}{\epsilon_0}[/tex]
For a spherically symmetric force, the left side of the equation can just be written as [itex]\oint \mathbf{E} \cdot d\mathbf{A} = EA = E(4 \pi r^2)[/itex] so [tex]E = \frac{1}{4 \pi \epsilon_0} \frac{Q}{r^2}.[/tex]
Thus the electric field falls off as an inverse square. But Iike I said, inverse square laws aren't, as far as I know, derived. Physicists performed experiments and then assumed an inverse square law, and all the other math came out of that. In fact, any inverse square law can be written in the form above, even the gravitational force.
Hi axmls,
I was thinking of the gravitational formula in particular:
(G⋅m1⋅m2)/d2
I'm just wondering what happens to the 4π part. Why isn't it written as something like this:
(G⋅m1⋅m2)/4πd2
G is defined with the 1/4π already applied. Its just a constant.
Remember, they could'a made G anyway they liked.
- stp
I also found this link from the Georgia State University site where they depict the gravitational force formula being something like this:
4π(G⋅m1⋅m2)/4πd2
Please check out the link:
http://hyperphysics.phy-astr.gsu.edu/hbase/forces/isq.html#isqg
it seems to suggest that the 4π cancels out, but I don't know why it appears in the numerator. My best guess was that it means to represent the virtual source point from which the gravity comes from.
What Steve Pitcher said. It's just a constant. In the case of electromagnetism, the term [itex]\frac{1}{4 \pi \epsilon_0}[/itex] is just written [itex]k[/itex]. It's a constant, so the [itex]\pi[/itex] terms are already taken into account.
In case you're curious, there's a corresponding equation for gravity: Gauss's law for gravity--[tex]\oint \mathbf{g} \cdot d\mathbf{A} = -4 \pi G M[/tex] In this case, [itex]\mathbf{g}[/itex] is the gravitational field produced by the mass [itex]M[/itex], and assuming a spherically symmetric field produced by the mass, the left side is [tex]\oint \mathbf{g} \cdot d\mathbf{A} = gA = g(4 \pi r^2)[/tex] so we have [tex]g(4 \pi r^2) = -4 \pi G M \implies g = -\frac{GM}{r^2}[/tex] So it's very similar to the case with electromagnetism. But again, it's assumed that gravity falls off as an inverse square--that's why we can write it in that form.
What is the area of the sphere with radius ##r_E##? It is ##4\pi{r}_E^2##.
What is the area of the sphere with radius ##2r_E##? It is ##4\pi(2{r}_E)^2##.
The ratio of those two quantities will be the ratio between the strength at ##r_E## and ##2r_E##. What is that ratio?
I am assuming here that you mean the inverse square law according to which the intensity of a point source of light reduces as the inverse square of the distance from the source. The reasoning for that is the following:
Assume a point source of light emitting power (Energy per unit time) Ps equally in all directions. At a distance r from the source, the intensity of light is defined as the power per unit area. How do we calculate this? Well, the power Ps coming from the source is spread out over a total surface area 4πr2. The intensity at that distance is therefore Ps / 4πr2. So the intensity falls off according to the inverse square of the distance. In words, it is simply because as you go further, the same power is spread out over larger and larger spherical surface areas.
Hi Chandra,
I'm interested in gravity in particular, because in the Newton formula for gravitational force the 4π is not there. To me, it makes it harder to explain in laymen terms the purpose of the inverse square aspect of the formula if the entire area of the sphere formula is not present.
axmls,
Thank you for posting the info about Gauss' law. It's over my head, but I think that must be what's depicted here:
axmls and Steve Pitcher,
I can't find any information that demonstrates that the 1/4π is already incorporated into the Universal Gravitational constant. Do you know where I could find more information on this?
Thank you
Ebenshap said:
Hi Chandra,
axmls,
Thank you
Yes, it all has to do with the fact that the surface area of a sphere increases proportionally to the square of the radius. Therefore, the strength of gravity is in effect spread out inversely as the square of the radius.
Also, the gravitational constant is measured, not derived from other laws, so when we say that the Pi term is already included, we don't mean that we canceled out Pi's and ended up with G. We literally mean that since G is just a constant, we could easily come up with another constant, like J for instance, such that [itex]G = J/(4 \pi)[/itex]. It makes no difference, so we go with the easy choice. Remember, it's the same number regardless. We just go with G. It's the same reason that in electromagnetism, we just replace the constant [itex]\frac{1}{4 \pi \epsilon_0}[/itex] with [itex]k[/itex].
As you say, the surface area of a sphere is given by [itex]4\pi r^2[/itex]. So if you have some quantity being "spread" over two spheres (imagine jam being spread on the two spherical pieces of bread!) we would have [itex]A= (4\pi r^2)d[/itex] and [itex]A= (4pi R^2)D[/itex] where "A" is the amount being spread over the two sphere, one having radius "r" and density (of whatever is being spread) "d", the other radius "R" and density "D". Since A is the same for both, [itex]4\pi r^2 d= 4\pi R^2 D[/itex] so [itex]\frac{r^2}{R^2}= \frac{D}{d}[/itex], the "[itex]4\pi[/itex]" terms cancel. That is why anything that is "conserved" (the total amount stays the same), as it spreads out, obeys an "inverse square" law.
Thank you for the clarification axmls. I think I get it now. Let me test out my understanding. Since the 1/4π is a constant, the original Newton formula simplifies the equation by factoring it out and making it a part of G. And so when Cavendish did his experiment to find the gravitational constant, since he was using Newton's formula, then that meant the number he came up with already included 1/4π.
Thanks HallsofIvy for the explanation. It looks like the 4π would only cancel out if it were being compared to another sphere and both spheres had the same source or two different sources of the same amount.
  • · Replies 33 ·
  • · Replies 18 ·
  • · Replies 16 ·
