How is a logarithm an exponent?
  • Thread starter Moonseed
    Logarithm
4 replies · 4K views · last reply
Moonseed
I need help defining a logarithm.
My book simply says: A logarithm is an exponent.
This stumped me because I can't see how that is. I don't know what question to ask, but I might not be apprehending the relationship between an expo. function and a log. function.
Well the logarithm base b is defined as
y = logb(x)
if
x = by
Notice that in the second equation y is the exponent, and in the first equation it is the logarithm, thus since these two equations are identical and express the exact same mathematical relationship it follows that a logarithm is essentially an exponent.
Thanks, that helped a lot.
I'm curious about why 'x' ended up where it is when the logarithm was converted to an exponential function or vice versa.
When converting from an exponential to a log (We'll use x=by as an example), you bring the y down. This bumps the b down into the base (Making it x=by). Then you switch the x and the y (Finishing the conversion to y=logbx). Did that make sense?
In technical terms, the logarithm is the "inverse" of the exponential function. That is, you swap the "x" and "y" values: if y= f(x) then x= f-1(y). As Ateowa said, if y= logax then x= ay.
